Results 1 to 16 of 16
Thread: Headers.... I need some, have some!!!
    BadAsp427's Avatar
    Greeneville, TN
    Ok, so I just got off the phone with FF and found out that the Hooker headers that I received with my 20th Aniversary kit have been discontinued. These headers are for a 351W and my engine that I have ordered is a 347 from BluePrint. The original plan was that I would swap them with FF for 302 headers, but because they are no longer using them, they will not exchange them for me.
    Does anyone have a good source for Mk4 headers connecting to the FF SS Sidepipes? Anyone need a set of headers for a 351W for a Mk4?
    Edmonton, AB, Canada
    That isn't good, I need a set of headers for a 351w but I am up in Canada, not so easy for me to get them from you . Are they not supplying 351w headers at all anymore or have they just changed suppliers?
    Unless you find someone who wants to swap their 302 headers for your 351 ones your choices are FFR and Gas-N.
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by SDhemmings View Post
    They have a new supplier. It is not easy to ship to Canada? I'd be happy to work with you. These are in the box and in fact, the box has never been opened since it was shipped to the original owner of this kit. Since I knew that I can not use them, I have not opened the box either.
    I believe these are the ones that I have: http://www.factoryfiveparts.com/16440-351-header/
    BadAsp427's Avatar
    Greeneville, TN
    I'm in contact with GASN, Georgie... That's who you are talking about correct....
    Southern Ontario
    I'm sure it's just those headers that are not available anymore. They still sell the 351W headers.
    Higgy
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
    Can't you get the BBK 302 headers from FFR anymore?
    http://www.factoryfiveparts.com/14858-302-headers/
    BadAsp427's Avatar
    Greeneville, TN
    I'm not sure about these headers part # 14858... The invoice FFR sent me yesterday is part # 16294 as the header they are now selling.
    BadAasp, Hey no problem, maybe send me a PM with what you want for them, I am more worried about any customs issues more than anything else. I will look into shipping.
    Kearney Nebraska
    Hey BadAsp, Just to weigh in with some BPE insider info...you'll want to get the new 302 headers from Factory Five. Their new headers are made to fit BPE's heads. The exhaust mounting location is slightly different on our performance heads as compared to Ford's stock heads. This is pretty common change among performance head manufacturers, because to squeeze more power from the heads we need to raise the ports slightly. The change doesn't make much difference in a Mustang or a Bronco, since the headers stay tucked in next to the engine. But when you have them on a Cobra, where the exhaust goes all the way out to the edge of the car, the small change is multiplied several times over. If you don't use FFRs headers you will have issues with the exhaust headers not lining up properly with the openings in the body. I know that Papa ran into issues. I believe he had some custom headers made by another manufacturer, so that would be another option.
    Serial #9158
    Senior Member Joe Campbell's Avatar
    Idaho Falls, ID
    Sent you a PM, I have a set made by Stainless Headers.
    Quote Originally Posted by Joe Campbell View Post
    Stainless Headers no longer builds headers, but only offers kits & tools that allow you to build your own. They will direct you to GP Headers if you want a set made for you.
    BadAsp, I may be the person you're looking for. I have a set of 302 4-4 Gas-N headers that were sent to me by mistake... I have a 351. Georgie said they cant use them anymore and that I may keep them, put em on a shelf, make art, whatever. Now these did not fit my 351 based engine very well at all and were hitting on engine mounts and I opened up the head mount bolt holes a little... nothing that should affect serviceability. Engine was never run through these.
    I'm willing to get these to you for shipping only. I have a set of Gas-N 351 4-4 headers for my car, but am willing to see if the F5 headers are better.
    Wanna trade?
    [edit] I now see that your cylinder heads have altered or relocated ports. I've been informed by Georgie that my Gas-N 302 headers will not fit your engine. Sorry... [/edit]
    BadAsp427's Avatar
    Greeneville, TN
    Wanna trade?
    Well ok then.... I was reading along and getting very excited... I'm in contact with Georgie as well... I wonder if that is why he said they wont fit...???? Thanks for thinking of me...
    Now, if you are interested in the headers I have, I would be willing to sell them as I need to get the funds to help pay for the new set from Georgie. These are what I have now... Brand new, in the unopened box... http://www.factoryfiveparts.com/16440-351-header/
    When it was looking at a straight up trade, I was excited too. Just to compare the Gas-N's 351's to FFR's 351's. Not that I'm unhappy with what I have... I was just looking to compare and this wouldnt have cost anything.
    I'm good as far as buying your set. I dont need to spend the $ just to look... Thanks!!
    Boyd,
    Back when I was working with Georgie to resolve my fitment problems, he bought and shipped a set of the new FFR BBK 351 headers to me to try. They fit perfectly. The only thing I didn't care for was the 2" bolt spacing vs. the 3". The 2" spacing does allow for a nice high arch between the cylinders to make it very easy to get to the plugs and to pull and replace the plug wires. Our heads have both, so the FFR headers will definitely work. I ended up going with another brand more for the double collector than anything else.
