Thread: Floor heigth of truck bed
    Aug 2018
    Has any one modified the frame to lower the bed floor height to it proper level? I understand that FF is using the roadster frame to save on tooling, but doesn't this truck deserve to have a proper looking bed?
    Rotonda West Florida
    Quote Originally Posted by LonJ View Post
    Changes to the chassis would ruin the rear suspension.
    I've been looking around for another example I have that is a '32 with an open bed to demonstrate but the fact is that when a truck is slammed like the '35, the bed is usually raised to clear the rear suspension. Here are a couple of steel-bodied '32s as examples:
    In both cases you can see that in order to have a flat bed, it has to be raised to clear the rear suspension.
    HTH,
    EDIT: Here are a couple of shots of a "normal" '35:
    ...and a normal truck bed depth:
    Finally, here's the FFR '35. Compare it to the steel-bodied rods at the top of this post:
    Senior Member Presto51's Avatar
    Catonsville, Maryland
    Easier to put a tonneau cover on the back and store your gear, than to modify the chassis, which would require a complete new redesign, defeating the purpose of a kit that you can put together in your garage.
    I guess you can call me lazy.
    Ron
    Senior Member TDSapp's Avatar
    Frisco, TX
    If you lower the bed much more then you have to move things into the bed. for instance....
    Tim Sapp
    11110001101
    33 Hot Rod
    Delivered 5/31/2017
    Senior Member Tom Veale's Avatar
    Wisconsin
    Quote Originally Posted by Presto51 View Post
    Easier to put a tonneau cover on the back and store your gear..................Ron
    Yes, A couple of bows and fixtures, like a sailboat cockpit cover would do the trick.
    Tom
    Oct 2018
    ada minnesota
    I am thinking of building a alum diamond deck hip roof with about a foot of riser under it but want to keep it below rear window, I cary a lot of junk in trunk usually my car trunk and whole backseat is full, I want to road the truck a lot
    PS I did a rear wheel bearing on a merc on labor day sunday in a motel lot in Illinois
