Results 1 to 10 of 10
Thread: Where to Buy Edge Guard for Seatbelt Openings?
    My kit came with a short length of white flexible edge guard that I used most of in the opening through the firewall to the footbox to protect the wire harness. I'd like to find more of this same guard for the openings in the rear cockpit wall for the seatbelt openings. I've found plenty of the metal u-channel stuff, but no luck finding the plastic. Any good sources out there?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Senior Member chmhasy's Avatar
    North CT
    Not sure if McMaster Carr has it
    https://www.mcmaster.com/
    Quote Originally Posted by chmhasy View Post
    I looked there first, but didn't find it. They have pretty much every other type of edge guard.
    Legal: 1/30/2020
    Raleigh NC, OIB NC
    Have you considered CNC inserts?
    Kevin
    MKIV #8234
    Cool idea; do you know of a source? I assume they would need to be custom made.
    Legal: 1/30/2020
    The way those openings are designed, the shoulder belts rub at the bottom across the wide and relatively smooth 3/4-inch tubing across the back wall. The aluminum back wall should be slightly below the tubing. So no real worries there. The rest of the opening can be smoothed out and dressed up with these: http://www.replicaparts.com/seatbelt%20page.htm.
    Senior Member karlos's Avatar
    Aug 2013
    Littleton, CO
    Dave,
    This stuff? If so you're welcome to it. I have 2 pieces, each about 15" long. PM me your address and I'll throw it in an envelope. Or if you're ever down my way (Littleton) feel free to stop by and pick it up.
    -Karl
    MKIV Roadster #8641
    Complete Kit with IRS, Eaton Detroit Truetrac, 3.55 gears, Wilwood Brakes
    Ford Racing Z427 w/ Pro-M Sequential Port EFI System
    TKO 600 + McLeod Midshifter; Fast Freddie's Electro-Hydraulic power steering
    Miller Customs Bodywork & Paint
    Quote Originally Posted by karlos View Post
    Dave,
    -Karl
    That's it! I'll happily cover the cost of the part plus shipping. I'ii send you a PM.
    Legal: 1/30/2020
    Paul,
    I have a set of aluminum bezels from Finish Line, but thought it best to guard the belts. It looks like Karl has some, so my search is over.
    Legal: 1/30/2020
    Raleigh NC, OIB NC
    Mine are from Mike Everson. Solid polished alloy 3/16 thick no sharp edges counter sunk screw heads.
    Kevin
    MKIV #8234
