Likes Likes:  3
Results 1 to 16 of 16
Thread: Coyote radiator hoses
    Apr 2018
    I am trying to hook up the upper radiator hose. I have the power steering kit provided by FFR for the coyote.
    When I put a factory hose onto this, it hits the pulley/belt for the power steering. For the hose to fully seat, it has to be at this angle.
    It appears that the hose and the fitting on the motor have a slot that mate.
    I am using the hose that was supplied with the coyote as well as the hose suggested by Edward (2012 f150) with the same results.
    Any one have a solution for this? If I grind the slot off of the hose, will I still get a good seal? Can I rotate the fitting on the motor? I'd like to keep the press style hose if possible.
    Norton, MA USA earth
    Just cut off the locating tab. It will not cause it to leak.
    Apr 2018
    So I cut the tab off. The hose seals but spins pretty freely. I'm not a fan of it. I'm going to source a hose that it straight and will find a way to route it. That way if it spends, it won't hit the belt.
    Agree the clearance in that area is really tight. But I've done two like that and neither actually hit. Not sure what the variation would be. The only difference between the hose provided with the kit and the F150 one is the shape of the hose itself. I think the clocking on the fitting is the same for both. I hadn't heard of cutting off the tab until Mike suggested it. Not sure why that wouldn't work. With the other end tied down, it's not going to spin or likely even move.
    Apr 2018
    I cut the tab. It appears to have been a mistake. Even with the other end tied down, it moves more than I I'm comfortable with. I am going to have to buy a new piece and replace it. I am thinking I am. Going to ground down the plastic on the pipe end. It appears I am either more cautious than most or this new krg power steering system hasn't been well thought out. I'm going with the first option.
    If you don't like that the hose can rotate a bit, place it were you want and secure it with a small bead of silicone. After looking at your pics, I think I cut the tab off and also cut the plastic hose retainer off and rotated both. Then used a simple hose clamp to put it back together.
    Senior Builder lgordon's Avatar
    Bellevue, WA
    IMG_3552.jpgIMG_3551.jpgIMG_3567.jpgIMG_3561.jpgI found a different solution to the interference between the coyote upper radiator hose and the KRC power steering belt/pully. Instead of cutting the locating tab off the fitting on the motor, cut a new slot in the fitting on the hose. That way you can decide how much clearance you want from the belt and have the connection locked in the way Ford intended, just at a different angle. Using a 2012 upper radiator hose as Paul suggested the installation was easy. I've attached a few photos.
  8. Thanks richtersand thanked for this post
    Likes tbl100, Marti50 liked this post
    Folsom, CA
    Quote Originally Posted by lgordon View Post
    that's super clean looking!!!!
    also, the upper hose is on sale right now for $39!
    Motorcraft - Hose - Radiator (P) (KM5114)
    Todd
  10. #9
    Nov 2019
    Charlotte, NC
    Mine is close to the belt, like a couple widths of paper close, but not hitting with the F150 hose.
  11. #10
    That is a really clean set up. I might change mine over. Where is your filler cap?
  12. #11
    Senior Member Hacksaw84's Avatar
    Jun 2017
    Quote Originally Posted by Dthquazi View Post
    I didn't cut the tab. Just sanded down a little extra clearance on the outside to make me feel better. Seems to not have any issues.
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
  13. #12
    Folsom, CA
    pretty sure the filler is the overflow tank
    Todd
  14. #13
    Raleigh NC, OIB NC
    Its on the expansion tank with F150 or similar hoses. For the Coyote these types of tanks will save you a lot of grief with coolant loss & air pocket removal. Don't have PS so the standard F150 hose is on the car.
    Kevin
    MKIV #8234
  15. Likes Marti50 liked this post
  16. #14
    Senior Member tbl100's Avatar
    Mar 2019
    Roseville, CA
    I cut a new kotch in the hose connector so it locks in.
    Mk4 Complete Kit delivered 5/2019, Gen 2 Coyote, TKO 600, IRS, Wilwood F/R, Power steering, Halibrand 17” X 9” Front 17” X 10.5” Rear, Nitto NT555 G2 F/R
  17. #15
    Senior Member richtersand's Avatar
    Jul 2020
    Newport Beach, California
    Just completed this mod. Such a simple/elegant solution. Went from unworkable to plenty of clearance. Great tip, thanks lgordon!
    Matt
    FFR Complete Kit, Coyote, Tremec TKX, 3.73 IRS, power steering, 18" Halibrands, Wilwood brakes, Gas-N pipes + header, Viking blue color
    Roadster Build Time Tracker
  18. #16
    Prescott, AZ
    PBH Upper Radiator Hose Adapter
    Another option is to purchase the ACC-1073 Upper Radiator Hose Adapter for the Coyote from Power by the Hour. With their adapter installed, you can install the hose of your choice. I have it on my Mustang restomod and using a cut down Gates hose I eliminated the interference issues. The C&R radiator I am using does not have the angled upper hose connection as does the radiator for the FFR which prevented me from using the F150 hose option. Just thought I would let the FFR builders know about the PBH upper radiator hose adapter.
    https://pbhperformance.com/product/c...-hose-adapter/
