I purchased a Dayco 71713 radiator hose and a Jegs 90 degree SS tube #679-MB1040. I found that the connection on the bottom of my radiator points upward while others point downward. I was still able to fabricate the hose but used a different section of the 71713 hose and went over the anti-sway bar rather than under. I used the hose that came with the Coyote for connecting to the engine. After a good bit of trial and error, trimming of hoses, and cutting of the SS tube I was able to get it to fit like a glove.
The Dayco 71713 before cutting.
Finished product with T-bolt clamps and salvaged braided loom
Connection to the radiator
Connection to the engine
And the SS tube crosses the "X" tube at 90 degrees so I will be able to secure it here using the Breeze mounting bracket #70612 which I have on order, just zip-tied it for now.
