Results 1 to 16 of 16
Thread: glovebox + heater question
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    as I get closer to the much-anticipated 'ready' date for my mk4 roadster kit, I'm working to finalize some of the option details for my kit. One open question is whether or not I get the factory dash with glovebox option and/or the heater option. The Commander (wife) is indicating that she'd really like a heater in the car which, as I understand, would be in the way of the glove box. However, I see that FFMetal has a new 'firewall forward' kit for the Mk4 that moves the firewall forward 1.5". So I'm wondering if a firewall forward kit would allow me to install both a heater and a glovebox, and whether the firewall forward kit will fit with a Coyote engine which I believe sits more rearward than a SBF?
    The Coyote sits further forward than the SBF. You should be fine with the firewall fwd kit. Not sure that the extra 1 1/2" will allow you to fit the stock glove box without some modification, but there are a number of ways to modify the glove box to work around the heater.
    Senior Member FLPBFoot's Avatar
    Cape Coral, FL
    John,
    I have installed the firewall forward option with heater and the FFR dash with glove box. You will have to cut about 1 inch out of the front of the glove box and install a panel to block it off. I used some AL sheet to for the new front then flocked the inside of the box. From the outside you can hardly notice the step down in the glove box.
    2nd MK4 #10639 received 3-19-23. Wife's version. Street Snake - IRS, Willwoods, no roll bars, no hood scoop, no stripes, Blue Print EFI 306 with AOD trans, and under car exhaust. Ford Eruption Green with saddle leather interior.
    1st build - Mk4 Roadster #9319, received 4-10-18. IL registration 8/6/19. Moser 8.8. 3 Link. Wilwood brakes. Blue Print 427, Holley 750, TKO 600, 0.64 OD. Paint Dec 2020. Ruby Red with Carbon Flash Black metallic stripes.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    That's great - thank you both!
    Kirkland, WA
    If The Commander wishes heat, you should also look into seat heaters. Some folks use heated jackets from the motorcycle world. Both will require 12V supplies, which are easy to install during the build.
    Hi John,
    The FFMetal firewall forward kit is not a direct fit when installed with the Coyote. The Coyote DS footbox aluminum is configured a little different to allow the wider engine to slip into place. The firewall forward piece is made as a direct fit with the non-Coyote DS footbox. Having said that, if you are handy, the piece can be modified. There are some threads on this forum that discuss installing both the heater and the glove box in a conventional FFR firewall. To accomplish this, you basically build a mounting box for the heater that sticks out into the engine bay about 2 inches. This mounts to the firewall and provides space for the glove box.
    I have the heater/defroster, the Cobra heated seats and the heated motorcycle liner. Like any outdoor sporting activity, you have to dress properly. I did not opt for the glove box and find I can store everything in the door panel pouches and behind the seats.
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Dave - thanks for the heads up on the firewall forward kit not being a direct fit with the coyote footbox aluminum. Much appreciated! Yes, I've seen the thread where the 2" box was built to space the heater forward into the engine bay. That also looks like a good way to go, and an excuse to finally buy that box and pan brake I've been wanting to add to the shop.
    For sure there will be seat heaters. I also come from a motorcycling background (BMW R1200GS Adventure) and I already have a heated jacket and heated gloves. Those are lifesavers when it's 30-40 deg outside! It would be very easy to have a couple of outlets or even little coax pigtails tucked under the seats to be able to plug heated gear into. We don't have a ton of rainy days around here, but the addition of heating options would greatly increase the number of days I could coerce the wife into joining me on a cruise.
    BadAsp427's Avatar
    Greeneville, TN
    Here is the modification that I did with my FF Padded Dash... I do NOT have the extra 1 1/2" forward so If i did i would have that much extra... but having said that, here is an option. CLICK HERE to see my modificaion
    Jax Beach, FL
    I have a SBF, but here is what I did. I moved the heater to the middle of the firewall and have a full sized glove box. I originally wanted all parts of the heater on the inside of the dash. However, it made it very crowded and the fan was too loud. I have the fan in the engine compartment and the rest is inside. Works great.
    I am also a fan of heated seats. Even in Florida, I use them quite a bit.
    As of about two years ago, there is no difference between footboxes for any engine option. The only difference is the driver side front, depending on whether you install a Wilwood pedal box or a Mustang pedal box. Both are the same size, just with different cutouts. Typically both are included with your kit. Factory Five used to provide an inside wall piece for mod motors that provided more room for the engine (at significant loss to the driver's foot space) and then used it also for the Coyote. But that's no longer the case. The entire footbox was re-designed to provide enough room for wide engines and cuts back out where your feet go so that space is mainly restored. It's been tweaked since providing a little more space for the driver's feet on the left side. All Roadsters now come with this footbox sheet metal, and is intended for all engines including the Coyote. Since FFMetals has a relatively new owner and re-introduced the firewall forward mod, I have to assume it's compatible with the latest sheet metal. Just call and ask or perhaps someone with recent experience will confirm.
    X2 the Coyote actually sits forward slightly compared to a SBF. An adapter plate is included for the transmission mount to accommodate the slightly forward location. X4 on seat heaters. Highly recommended and have my wife's enthusiastic approval. I like them too, just not always on the high setting.
    There was a FFCars.com vendor, selling a shallow, pre-made glove box, a few years back, designed to work with the heater installed.
    Sounds like you're talking about Alex's Custom Roadster Interiors. http://acroadsterinteriors.com/Gloveboxes.htm. I used his standard glovebox and covering on #7750. Turned out nice. I've seen the shallow box version on a buddies car. Does what it's intended to do, but it's not hinged and is only deep enough for papers and not much else. Mainly to give the glovebox appearance. Not sure this is an option for the OP since it sounds like was considering the FF pre-made dash. Also I've heard/seen various accounts of whether Alex is still selling these items.
    RR20AC's Avatar
    Puyallup/WA
    Here you go. 2.5 inch bump out and sweat some elbows on the core tubes and you can have both. Paul2stl did it with a coyote and it worked too.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Hi John - I added both a glove box and the Vintage Air heater to my Mk3.1 build. As others mentioned, seat heaters are a great idea, too. For me, the heater was really intended to be used for defrosting the windshield with the top up. I've found that down into the 30's, with the seat heaters on, I can get more than enough warmth in the cockpit by simply adjusting the heat temp control without actually having to turn on the blower.
    Here are a couple of pics - the first is my somewhat period-correct dash... a combination of S/C instrument layout and a glove box that I fabricated myself, starting with just the blank that was cut from the dash for the opening.
    This pic shows the inside of the glove box - it's really just an aluminum panel that I covered with leather and screwed to the heater box. The ends (not visible) are bent towards the rear of the car and I used some weatherstrip edging to seal it to the back side of the dash panel. It's just over an inch deep, but more than enough for insurance and AAA card, tire pressure gauge, driving gloves for cooler weather, some spare foam ear plugs for passengers, and a few other odds and ends.
    Later,
    Mk3.1 #7074
    Lilburn, GA
    I made my own glove box and heater bump out.
    The bump out is 2.5". The glove box is 3" deep on the top and 4" on the bottom. Mine is aluminum and welded together but you could form it and rivet if you don't weld.
    https://thefactoryfiveforum.com/show...l=1#post276292
    FYI... Used the supplied heater 90 degree elbows supplied and a 4-way shutoff valve.
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    I took a little more difficult route, using the supplied FFR firewall and blank dash... Glovebox
    Scroll down for more installments.
    John D. - Minneapolis 'Burbs
