Results 1 to 14 of 14
Thread: New Rear Shock Mount
    LS MAN's Avatar
    Stockton, CA
    Prototype of new shock mount. Increases rear rise height approximately 5/8"
    Allows more adjustment on rear spring, without having to crank on adjuster so tight.
    Allows more shock droop travel.
    Should be less expensive to manufacture.
    Let me know what you think.
    Aug 2011
    Beautiful part! Estimated price? Interested, but no rush....
    thanks
    Aman
    Member sressue's Avatar
    Marion, New York
    Great looking part. Could solve a couple of issues . I would be interested in purchasing if the price was right. Nice work.
    Senior Member Joe Mush's Avatar
    Canton, MA
    Nice work Ted. what's the price going to be.
    Charlotte, NC
    Hi Ted,
    If we already have the First version of the Rear Shock Mount, would you say that we're probably good, or is this another upgrade from that? It looks like a really solid part (as all of your parts do). I'm getting ready to switch out the shocks as soon as I get the car back. So that would be a good time to make the switch, if needed.
    The Stig
    GTM #0081
    LS MAN's Avatar
    Stockton, CA
    Quote Originally Posted by Joe Mush View Post
    Hey Guys, still working out the details - trying to get the price under $300 for the set
    LS MAN's Avatar
    Stockton, CA
    Hi Ted,
    Hey Stig, You are fine with the steel mounts, unless you need more ride height adjustment. When I designed the 1st gen., I matched the FFR mounting points, one reason I made them out of steel.
    Seems now that we are running out of height adjustment/shock travel - so the updated design.
    Also the steel mounts are a PITA to build!
    GTM Builder/Owner
    Ted,
    How are you getting more ride height adjustment and more droop? If the bottom shock mount is closer to the control arm, by how much?
    GTM #26
    Stock LS-6. PHII G50-50, Shane's Louvers, Nordskog Dash, Shaved Door Handles,
    David Borden's Aluminum Dash Cover for Nordskog Dash,
    Roll Bar Covers -- http://quickracingproducts.com/html/interior.html
    LS MAN's Avatar
    Stockton, CA
    Hey Mike, the new design raises the mounting point approx 3/8" higher off the control arm than the 1st gen. With the motion ratio of the suspension, that equates to about 5/8" more ride height by just changing mounts.
    Member Ron565's Avatar
    Clayton Ca,
    Can't wait to get a set on my car.
    I also want to get different shocks for sure.
    Ron
    Senior Member rev2xs's Avatar
    Wysin, Poland
    Is there any news on this product?
    I cant seem to find this version on the quickracingproducts site.
    The old version is there, which is fine. So i might go for that. I posted a thread on the other forum asking for who produced this, guess i found out here ha ha
    Newcastle, Wyoming
    Ted,
    I would also be interested in a set of these, great looking mount.
    Wysin, Poland
    Hi Ted,
    Any updates on this perhaps?
    I think there is a lot of us who would be eager to get their hands on this.
    San Diego
    I heard thru the grapevine that Ted thought the original all steel versions were too complicated to efficiently produce. Probably what led to the machined parts. I have never seen any of those machined versions in real life so no real answer as to whether they are available or not, but I do believe Ted was looking for an easier way to produce these.
    www.myraceshop.com
    GTM solution kits
    Corvette and Race parts
