Aluminum Grease Fitting Caps
I am about to place an order for some Aluminum Grease Fitting Caps (apparently these are extremely difficult to find). On the standard 33', I believe there is (18) required. If anyone is interested in piggy-backing on my order please let me know within the next day or two (you can pm me). Current pricing is $5.00 each < 36, $4.00 each 37 to 99 and if we can get to 100...$3.25 each. We will have to calculate shipping, if other's are interested. Below is a pic...
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
Post Thanks / Like - 2 Thanks, 0 Likes
Papa
Good point and I will check into it...hope the caps fit existing fittings as my time to remove and re-install new fittings would be worth the additional $1.35 a piece .
JOP33
I'm in if you decide to order. Tim W is sold out and they weren't that popular apparently so he isn't going to place another order.
I'm in Jamie! Whatever you order, get a set for me. Maybe a couple extra??
Larry
JOP33
I don't think the caps will work without the fittings. Sorry to hijack your thread. I just thought they looked like a decent alternative.
JOP33 thanked for this post
FF33rod
Ok Steve, yes I had checked with Tim as well and got the same answer a couple of months backs. I’ll add you to the list and let you know when I order.
MBB Larry
Larry
Got you down Larry.
