![FormaCars](https://thefactoryfiveforum.com/attachment.php?attachmentid=62553&d=1483735916)
22
2x on keeping the back wall smooth... Thinking back on it, if I was to do it again, I'd probably tear out little nubs (halfway through) of the sheet padding I used over each rivet head, then glue it in place - smooth side out.
The only place where the rivet heads printed through that's visible is between the seats... nearly all others are concealed.
John D. - Minneapolis 'Burbs
![FFMetal](https://thefactoryfiveforum.com/attachment.php?attachmentid=195371&d=1707243047)
