Results 1 to 16 of 16
Thread: Brake line route question
    West Linn oregon
    I am running my brake lines now and have the front lines mocked up with the stock brake line material. I will change to stainless when I am happy with the route I chose. I ran the rear lines up and out of the master cylinder, my front line I ran down and out of the master cylinder. Is there any problem running the brake line turning down exiting the master?
    cv2065's Avatar
    Picture?
    West Linn oregon
    You cant see the pic?
    Shows on my computer.
    cv2065's Avatar
    Quote Originally Posted by bluse View Post
    Sorry...don't see anything.
    West Linn oregon
    Can anybody see the pic below?
    Southern Ontario
    Nope
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
    Nope
    Double Ditto "Nope!"
    West Linn oregon
    Not sure what the problem is but the 90' fitting leaving the MC points down instead of up.
    No. Orient the fittings however works best for your planned brake line routing. No picture showing here either BTW.
    I concur.
    West Linn oregon
    Thank guys, I didn't think it mattered but wanted to make sure.
    The pictures look great when I pull the thread up, not sure what's going on. Not sure it matters that I have a Mac?
    EDIT: Investigating... Found it.
    bluse, PM sent.
    Grand Rapids, MI
    I see the photos.
    Jim
    Pics are up now! That should work fine... no issue to hydraulics as to which direction it goes.
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Shows up fine for me.
    Ray
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    No issues with up/down/sideways... but one thing to keep in mind is future serviceability.
    It gets REALLY busy in that space a little later in the build. If you have to replace a master cylinder down the road give consideration to the access to the fittings.
    John D. - Minneapolis 'Burbs
