Results 1 to 11 of 11
Thread: Roadster Fresh Air Vent
    May 2018
    Merritt Island, FL
    I wanted to add a fresh air vent to the drivers side of my Mk 3 but I didn't like most of the installations I saw- 3" duct mounted fairly high in the engine bay.
    With the car up on a lift, it looked like a 2" duct would nestle along the frame below the lower A-arm.
    It does.
    Here what I wound up with. I used 2" stainless exhaust pipe I had, some 2" defroster duct, and a repurposed Explorer throttle body for a control valve.
  2. Likes Snakely liked this post
    Senior Member Walt's Avatar
    Dec 2013
    Navasota, Texas
    Neat idea!
    FFR8237 Donor build 89 GT , MK 4 , T5 , 17 " hallibrands 9" front 10.5 rear ,4×4 headers stainless mufflers, dual chrome roll bars, coil overs all 4,A/C and heater , soft top, 3:55 gears.
    Clever. Love the throttle body. One man’s junk is another man’s treasure.
    Are you putting a screen at the intake end, to prevent a wasp ending up in your footbox?
    May 2018
    Merritt Island, FL
    No- I'm not that concerned but I could just shove some screening in the intake, I guess.
    Can you see it through the wheel well?
    May 2018
    Merritt Island, FL
    Quote Originally Posted by silver_pilate View Post
    Not really- it's visually blocked by the wheel.
    RJD's Avatar
    Northern Virginia
    Pretty slick!
  10. #9
    Nicely done. I would keep my eye open for an inlet piece to gather air from the entire opening.
  11. #10
    May 2018
    Merritt Island, FL
    Yes- I could use the brake duct inlets but I'm not sure that will be necessary. I haven't had a chance to try it out yet due to a sprained left ankle and cold weather.
  12. #11
    Jax Beach, FL
    Interesting idea on the throttle body. I used exhaust cutouts for mine.
    My opinion is you should put mesh in both cosmetically and functionally. The only issue I see is that the tube will likely end up with a lot of sand and dirt in the low spot. It would only be a 1 minute maintenance item though.
