Yes, I love Technology
Clamshell front end ?
I'm wondering if anyone has converted the front sides and hood into a single clamshell, nose-hinged aka Corvettes, etc.? I loved the way my 90 Vette opened up that way. I've been looking at the parts and thinking that would let me eliminate the fitup of those parts, make it overall sturdier and smoother lines and of course be another excuse to change things up.
I don't recall any build logs doing that, but I know some non-build log guys read and post now and then.
Thanks -
Yeah, there's been a lot of talk on the forum but I don't think anyone has actually done it ( at least anyone who has a build thread).
It would make working on the front end a lot easier though wouldn't it.
If I was going to make a clamshell, I'd make the rear open up instead of the front. That's where the action is. There are but a few items up front that need servicing, vs the jewelry box in the rear.
I have a Lotus Elise with a hinged rear clam shell. It is very nice for getting quick and complete access to the engine / driveline/ etc.. It would require a light sub frame be built to add structure to the rear panels.
Hmm... maybe a new project for next winter.
If you are looking for a the actual assembly used for a C-4 Corvette, then you will likely be able to find it at:
Dino's Corvette Salvage.
https://corvettesalvage.com/
Dino's is likely the largest Corvette Salvage Yard in the U.S.A. and is located in Southwest Mississippi.
Good Luck!
NOTE:.. I've been there many times since that yard is about 25 miles from my home.
I like the idea of a rear clamshell the ideal would be to have the rear open with the wing and mounts attached. And without adding weight, this is a personal OCD thing. LOL
The rear would make sense. I went to Boston last summer for the coupe add on, not sure how that would work
Several of us have done it on the Cobra, but I'm assuming you are talking about the 818.
Someone has to be the first. Maybe you can figure it out and post your progress.
FFR 7123 tilt front, Levy 5link/wilwoods/LCA's, webers.
SL-C, LS3 525, Mendeola SDR5,
There was also a lot of talk in the past about using dzus fasteners to be able to quickly take the body panels off.
flynntuna
I have done this. Not sure if it was worth the work, but it is nice.
Jumping out of my perfectly good airplane
I'm going for it. We've had 5 Corvettes and it just keeps coming back to liking that look. And a little more access, worth it or not.
I'm running it in my build -
https://thefactoryfiveforum.com/show...18-build/page3
around post 108
