Post pics of your zero decibel body vents
I'm going back and forth on mounting them on top of the panels securely with rivets or figuring out a way to mount from below. I think either way could look good if executed well. I've also seen other models use similar vents in both orientation. Pictures and experiences?
Mount them on the underside. Use small 10-32 button head bolts and locking nuts. Trust me you want to be able to easily take them out if you need to without damaging the paint!. I've already removed mine twice after painting.
IMG_20190320_163608.jpg IMG_20190320_163730.jpg IMG_20190320_163748.jpg IMG_20190320_163658.jpg
Lower rear louver....I know...it needs painting
Hood vents glued in underneath and engine cover vents fastened with 8x32 button head screws on top. engine cover vents.jpgHOOD VENTS.jpg
Just installed:
