Thanks Thanks:  85
Likes Likes:  149
Page 2 of 15 FirstFirst 123412 ... LastLast
Results 41 to 80 of 593
Thread: MJS Mk4 Build Thread
    Are these two panels at the trunk supposed to line up perfectly on fitting?
    Attachment 105220
    Theoretically yes however the two 90 degree bends at the rear of the trunk floor are done by hand so some amount of error is not uncommon. I often have to trim that rear lip so that the rear valance can be pulled in far enough to meet the lower edge of the trunklid.
    Working on the front suspension, anyone see any issues prior to moving on. Trimmed the rear control arm adjustment sleeves and anti-seized them but realized I may have to go back and trim the bolt as well. Does anyone know if that is required or is trimming the rear sleeve enough?
    I always cut back the male stubs as well so that they do not bottom out inside the sleeves.
    doddmoore's Avatar
    Mar 2018
    Jackson, MS
    HEY THERE! Just now seeing this build, welcome and I look forward to reading more. Best of luck to you. I know less than anyone but hopefully I can help at some point along the way, if not I will be looking to you for help before you know it.
    Mitchell
    "Doddmoore," Mitchell Moore on facebook, Follow Tonks347Cobra on Instagram
    MK IV Complete kit, SB Ford 347, Holley Sniper EFI, TKO 500, Moser 8.8 Solid axle, Wilwoods, Power Steering
    My Build Thread: Tonks347, The Baker's Build
    Slow and steady wins the race.
    Dec 2018
    Hudsonville, MI
    Thank you sir!
    So if I'm still still planning on you being my body work expert I can leave this alone correct?
    Dec 2018
    Hudsonville, MI
    Gotcha, I'll check back on the alignment and plan to do this.
    Dec 2018
    Hudsonville, MI
    Made some simple progress this week
    I noticed a slight list to the raised area of the caster wheels so I pulled the frame off and put 4 additional 6" lag bolts into every wheel support base. If this thing collapses it will stay where it lies.
    Did some work getting things ready for the IRS. Used a Sawzall and a 6TPI blade to cut the ears off the knuckle , then just ground them down with a Dremel sander and 320 emery cloth. Tapped the two ABS holes and put set screws (1/4-20, 7/16-20) in with red locktite. Saw this on another thread and thought it was a good simple solution...
    Rented this behemoth to torque the hub nut, but bought the wrong size socket, thought it was 1 1/2 but seems like it must be 36mm.
    Then cut the 5/8 hole in the corner of the knuckle and the drill went through like hot butter... so all was buzzing along just fine, enjoying the summer afternoon and all is well. Next step I get to in the instruction book casually states about the center section preparation "...chase the front mount with a 5/8 drill bit.."
    buzzing along with the dewaldt drill, bit catches hard enough to dead stop for the entire 90# center section to do a 360.. my arm goes the opposite way, wow, ouch. It was at that exact moment I recall someone else on here doing the same thing, probably countless others actually. Now being someone who depends on my hands to work everyday I would certainly be interested if there were a smarter way to go about this. Thought about a step drill but can't find one that maxes out at 5/8, maybe some sort of reamer? hmm. Gonna have to step back here for the night.
    General observations:
    1: It is impossible to have too many clecos.
    2: If you are building a frame dolly just build it as if you're going to put a tank on it.
    3: Look for weld spots to grind down before fitting and drilling position holes into the frame.
    3: When the build manual casually says to 'chase' something proceed with caution.
    Update: Ordered one of these reamer bits, looks like a smarter solution. We shall see.
    Dec 2018
    Hudsonville, MI
    Did you folks drill and rivet this bottom edge of the passenger footbox through the two panels into the frame?
    Dec 2018
    Hudsonville, MI
    Quote Originally Posted by doddmoore View Post
    Mitchell
    Thanks appreciate any help!
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I'm a little late to the party, but here are a couple of thoughts on a few of your items:
    - The threaded rods/bolts inside the adjuster sleeves are MUCH harder to cut than the aluminum sleeves. Being inherently lazy, I decided that cutting one was easier than cutting two so I cut one of them on each arm equivalent to the sum of the two pieces I took of the sleeve. I hope that makes sense. IOW, if I took 3/16 off each end of the aluminum sleeve, I took 3/8 off of one of the bolts. That still leaves a ton of thread inside the sleeve, and it also avoids the need to have to try to cut the one bolt that's welded onto the ball joint plate on the one arm.
    - As far as chasing those 5/8 holes, I had the same experience as you except I was using a cordless drill so it didn't spin the whole center section around but did spin the drill around a good ways and tweaked my wrist. What I found is that if I spin up the drill bit to max RPM first and then start drilling with very light pressure I could keep the bit speed up (and with some cutting oil on the bit) I could keep it from grabbing.
    - in case you haven't found it yet, here's the Howe Racing ball joint: https://www.summitracing.com/parts/HRE-22320S
    -John
    Dec 2018
    Hudsonville, MI
    It was remarkably easy to torque to 250ft-lbs on the hub nuts using this massive wrench. It’s a free rental from Autozone, I just paid the deposit and it’s full refund upon return. Would highly recommend if anyone is looking for one.
  11. Thanks Aircontroller thanked for this post
    Likes Aircontroller liked this post
  12. #51
    Dec 2018
    Hudsonville, MI
    -John
    Thanks for the info!
  13. #52
    Dec 2018
    Hudsonville, MI
    Center section front mount 5/8 drilling update: The reamer drill bit was no better and again currently feeling like my arm was nearly torn in half after round three still on the first hole. I am going to buy a 3/8 shank 5/8 bit and use the cordless as some others have recommended.
  14. #53
    Use the cordless drill and turn the torque way down. Most cordless drills have a selector for that. That way when it grabs (and it will grab) it slips the ratchet in the drill instead of nearly breaking your arm or wrist. It will take a few stalls and bites, but goes through pretty easily after a few tries. And yes I learned this the hard way too.
  15. Thanks Aircontroller thanked for this post
  16. #54
    Dec 2018
    Hudsonville, MI
    Use the cordless drill and turn the torque way down. Most cordless drills have a selector for that. That when it grabs (and it will grab) it slips the ratchet in the drill instead of nearly breaking your arm or wrist. It will take a few stalls and bites, but goes through pretty easily after a few tries. And yes I learned this the hard way too.
    Perfect! Thanks again. I am optimistic about round 4.
  17. #55
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    Wow! That's a beast of a torque wrench. Thanks for the tip. I have a 1/2" drive torque wrench that will max out at 250 ft-lbs but it's half the length of this one so it would be a fight to get to that torque. I'll have to track one of these things down when I get to that step here shortly.
  18. #56
    Dec 2018
    Hudsonville, MI
    Stupid question for the Day # 1.
    It’s ok to take an angle grinder and smooth some of these weld spots down so panels fit flush? As below.
  19. #57
    Yes, you can. Most of the time, I found it easier to notch the panel with snips or a Dremel. No paint to fix that way.
  20. #58
    Dec 2018
    Hudsonville, MI
    Nice, finally worked through the full size picture posting.
    Just working on panels over the last week. Everything south of the firewall has been fitted, marked, drilled, de-burred, re-attached, re-drilled. It’s hard to fight the urge to put clecos everywhere. Once everything is done in the next week I’ll send them off for powder coat.
  21. #59
    Dec 2018
    Hudsonville, MI
    Did anyone have to trim the inner sleeve of the center section mount bushings down. The rear mounts were the perfect length but the inner sleeves of the front mounts hang out about 2mm on the other side
  22. #60
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I just installed my center section a few weeks ago. I torqued the rear mounting bolts first, and that pulled the center section back tight to the frame. In that position, the two front mounts are pulled backwards slightly away from the frame. The attached photo isn't great, but if you look closely at the rear part of the front PS mount, you'll see that the bushing is pulled away from the frame mount by ~2mm. The DS is the same way. I think your inner sleeves should work fine the way they are.
  23. Likes Aircontroller liked this post
  24. #61
    cv2065's Avatar
    My inner sleeves were identical. I called FFR about the small gap when tightening, and they said that's how it was designed and to proceed.
  25. #62
    Dec 2018
    Hudsonville, MI
    Thank you!
    I appreciate the response from you both! Until I read this I was planning on hammering them out and trimming. Thanks for the insight.
  26. #63
    Dec 2018
    Hudsonville, MI
    Question for the forum:
    Fitting the cockpit back wall aluminum.
    o
    To line up the rear square bar with the cutouts for the seatbelts, I ended up with this uneven edge where it meets the corner panel.
    The other side is similar but a hair less.
    Should I re-fit this or will it end up ok?
  27. #64
    Dec 2018
    Hudsonville, MI
    First experience with the POR15 line of paint.. this stuff means business. My son wanted to ditch the sidewalk chalk and got in on the action for a bit.
    Still contemplating what to do about the aluminum mismatch as above, in the meantime installed the front swaybar. Only had to file out the bolt-holes on the swaybar itself and was a smooth install. Waiting on some parts to have enough to install the steering or IRS, but plenty to keep me busy in the meantime.
  28. #65
    The 3/4-inch bar cutting through the opening is intentional. That's to prevent the shoulder strap from chafing against the aluminum since it wraps over from the below in the trunk. As for the mis-match on the corners, I don't remember that on the ones I've done. Attached a picture of my #8674 build which shows them lining up pretty well. If you're sure the rear wall is down as far as it will go, e.g. to the cockpit floor, not much you're going to do there. You could raise the corner pieces slightly if it's not too late. But could be trimmed if needed and bulb seal goes across there anyway, which can absorb some difference.
  29. #66
    Dec 2018
    Hudsonville, MI
    Few extra rivet holes no one will see and straightened the whole section out.
  30. #67
    Dec 2018
    Hudsonville, MI
    Ordered aftermarket Moog power steering rack ends, are they supposed to be different?
  31. #68
    cv2065's Avatar
    Mine were the same. Looks like you have two different ones. I ordered the Moog es2150rl tie rod ends.
  32. Likes Aircontroller liked this post
  33. #69
    Dec 2018
    Hudsonville, MI
    Gotcha, that’s what I figured just making sure. That’s the order number I used as well. I’ll just send these back and try a different supplier.
  34. #70
    Dec 2018
    Hudsonville, MI
    Header Question: Anyone using a Dart 347 EFI use shorty or long headers? And for any reason in particular?
  35. #71
    Dec 2018
    Hudsonville, MI
    Does anyone rivet this whole section of the driver footbox together prior to powder coat or should they all be done separately
  36. #72
    Dec 2018
    Hudsonville, MI
    May not look like much but I think it took two hours to get this one panel aligned as well as I could using the improvised wooden-block sheet metal brake.
  37. #73
    With the drivers footbox outer panel and it's kick-out, I'd assemble, then powdercoat. No need to do the kick-out pieces seperately. However, be very careful with the silicone. Any silicone at all that squeezes out will prevent powdercoat from sticking.
    I saved the powdercoat for panels that would be seen and got the most abuse. I simply painted this panel on my car.
  38. #74
    cv2065's Avatar
    I drilled and then sent them to powdercoat separately, then assembled when I got them back. I'm sure either way will get the same result.
  39. #75
    Dec 2018
    Hudsonville, MI
    Thanks for the info gentlemen, I hadn’t thought of the silicone yet. I think I’ll just take exploded view pics on disassembly and coat them separately.
  40. #76
    Dec 2018
    Hudsonville, MI
    Couldn’t return the tie rod ends as I bought them on EBay and can’t get any response from the seller.
    Ordered some from local auto parts store but they wanted 62$ each. Would love to support them but 2 delivered next day on amazon for 50$.
  41. #77
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    You'll want to check the service temperature of whatever adhesive you use, and then find out what temperature your powder coater bakes at. The PC shop I use bakes the zinc primer at 400 F and the top coat at 500 F. I'm not sure all adhesives can withstand that temperature.
  42. #78
    Dec 2018
    Hudsonville, MI
    Thanks for the heads up!
    Wouldn’t have thought of that. I’ll just plan to have them PC prior to assembly
  43. #79
    Dec 2018
    Hudsonville, MI
    I’m not close to finalizing placement of panels yet but drilling this area got me thinking. Which way do you face the head of the rivet for this intersection where the clecos are?
  44. #80
    Southern Ontario
    I think you have to go opposite of the Celco's, from inside the footbox to inside the engine bay. When you put the motor in, you wont be able to see a thing.
    Higgy
    MK4 #11012 picked up 04/16/24
    351W, 3 link, single roll bar
    MK4 #10616 picked up 4/10/23
    MK4 #9759 picked up on 4/3/19
