Results 1 to 6 of 6
Thread: Length of coil over springs
    Mar 2013
    Fort Collins, Colorado
    If I put two springs on my workbench, both the same spring rate, one is 8 inches and the other is 10 inches, what are the arguments for using the shorter (or longer) spring ??
    Will one or the other have a better ride quality or performance ??
    What are the main reasons, other than fitment, for choosing one over the other ??
    MK2 #3319.... On the road since 2002 with a lot of upgrades
    Quote Originally Posted by Derald Rice View Post
    The only difference is what range of movement you need the spring to respond to.
    Both springs react to loads exactly the same way - xxx lbs per inch, until you run out of spring travel (completely compressed or completely unloaded).
    Quote Originally Posted by mike223 View Post
    I agree. I had been using 10 inch rear springs for ever. When I used my same 3 link rear shocks on the new IRS retro fit, I needed a bit more clearance so I used 9 in. I was concerned that I could possibly coil bind the shorter springs but fortunately QA1 now has a line of 'Hi travel' springs.
    We should probably also note that this conversation mainly applies to constant rate coilover springs as delivered by the manufacturer.
    If you were to just cut a 10" spring down to 8" you're going to change the spring rate (because a 10" spring is going to be slightly different in order to maintain the same spring rate as an 8" spring).
    Also OEM springs in production vehicles are often variable rate springs (all bets are off).
    I'm certain Craig knows all that - but you never know who else will happen along and read the thread.
    Seasoned Citizen NAZ's Avatar
    Agree with all the above. Now, selecting a longer spring with a lower rating and using more pre-load to achieve ride height will provide a softer ride and increase weight transfer.
    Agreed - ideally, you pursue that until you run out of suspension travel.
    Or until you set up poor handling characteristics by getting one end of the car too far out of balance from the other end.
    In oval track that could also involve getting one side of the car too far out of balance from the other side.
