Thanks Thanks:  44
Likes Likes:  161
Page 6 of 17 FirstFirst ... 4567816 ... LastLast
Results 201 to 240 of 654
Thread: GTBradley's build - Still Kick'n!
  1. #201
    Nov 2018
    Centennial, CO
    Yup... it's all cylinder head.
    Curious... what are your clearances PS & DS to the footbox tin?
    A full inch on the PS foot box. As little as a quarter inch on the drivers side. It’s a half inch on average, but at the bolt bump out it’s a quarter. Is that common?
    Bradley
  2. #202
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    That's just about exactly what I wound up with.
    John D. - Minneapolis 'Burbs
  3. #203
    Nov 2018
    Centennial, CO
    Can anyone help me with identifying which harness this Intercooler wire is in?
    Bradley
  4. #204
    Ford Coyote control pack harness.
  5. #205
    Nov 2018
    Centennial, CO
    Does it really need to be cut back, because I can't find it.
    Bradley
  6. #206
    No, it doesn't hurt anything to be there. But a little strange you can't find it. It's item P on the control pack harness, per the Ford instructions.
    https://performanceparts.ford.com/do...-6017-504V.pdf
  7. #207
    Nov 2018
    Centennial, CO
    Ah, thank you. I totally forgot to download that from Ford. I have been using the FFR Coyote Installation instructions exclusively to try and locate it. Everything has been fine until this FFR picture came up. I had identified the right wire on my own, but apparently the FFR picture is old because it shows the wrong colors and that threw me. You've got me back on track once again.
    Bradley
  8. #208
    Nov 2018
    Centennial, CO
    Paul, while you're at it, would you give me your thoughts on this location for my overflow tank? I know you didn't use the FFR tank, but do you think this location will work regarding hood hinges, etc? I can't go more aft as the engine is so wide, so I think I'm stuck with this side of the brake line or a different tank altogether.
    Bradley
  9. #209
    The front to back location will clear the hinges OK. Just watch the height. The gas shock for the hood drops down exactly into that area. Keep it below the bottom of the 3/4-inch hood surround tube (including with the cap) and you'll clear the gas shock.
  10. #210
    Nov 2018
    Centennial, CO
    So the Ford Controls Pack Instruction Sheet says the AC wires come off Takeout CCA, but their picture does not look like what I have. I'm assuming these (pictured below) wires are the same thing. Can anyone with Coyote confirm please?
    These are coming from Takeout CCA, along with the fan wire and starter lead.
    Bradley
  11. #211
    Per the Ford Performance Gen 2 Coyote Control Pack instructions, and my memory, the wires you're picturing here are from the 16-way I/P Pigtail cable. Not the main wiring harness. If those are really in the main harness, then something has changed. i know Ford Performance has made some changes with the later versions of the Control Pack. Later than the Gen 2 version I installed. If that's the case, maybe call the Ford Performance help line. Unless someone else on here has experience with a later version.
  12. #212
    Nov 2018
    Centennial, CO
    You got me to thinkin...I needed the M50A 2017 tech sheet. Those wires I was asking about are intended for Electric Power-Assisted Steering (EPAS) and this one does not have the option for A/C.
    Bradley
  13. #213
    There you go. Hadn't seen that update, but shows some of the changes I've heard about. Nothing that should affect anything with your build. Just different.
  14. #214
    Nov 2018
    Centennial, CO
    In fact, everything had been identical til the A/C wires were missing. Don’t know why they would omit those, but I hadn’t planned on air conditioning here in the mountains anyway.
    Bradley
  15. #215
    Nov 2018
    Centennial, CO
    Well, it's been a couple of months again since I updated the thread with details, so I'll try to catch it all up again.
    Bradley
  16. #216
    Nov 2018
    Centennial, CO
    Only minor scratches to the frame, but we apparently broke the LS O2 sensor plug. It still works and makes a good connection, so I have it zip tied to stay together. I'm not sure how to go about replacing it.
    Bradley
  17. #217
    Nov 2018
    Centennial, CO
    Transmission Spacers
    I made my spacers - three of them out of 1/4" aluminum plate I ordered from Amazon.
    Longer bolts were needed and 7/16" -14 by 1.5 inches long worked.
    Bradley
  18. #218
    Nov 2018
    Centennial, CO
    3/4" of lift provided by the spacers seems to align the transmission with the center sect just fine.
    Bradley
  19. #219
    Nov 2018
    Centennial, CO
    I found this badge online some time ago and can't remember where. I really like it but I don't know who sells it. Does anybody know?
    Bradley
  20. #220
    Nov 2018
    Centennial, CO
    Engine Bay Fuel Line Routing
    Routing the fuel line in the engine bay
    The fuel line for this setup has no return line in the engine bay, and the regulator is back at the fuel tank so this is super easy and clean. As a result, the vacuum line that would go to the fuel regulator is capped at the engine.
    Bradley
  21. #221
    Senior Member Jdav's Avatar
    ATL GA
    Wareaglescott has them. I believe he got them from https://www.billetbadges.com/
    MK4 #9028 - Coyote - TKO600
  22. #222
    Nov 2018
    Centennial, CO
    Radiator Mounting - Breeze
    Radiator installed using Breeze upper and lower mounts. The piano hinge makes setting the correct angle a...well...let's just say it, a breeze.
    Breeze fan shroud and radiator stainless hoses:
    Because the lower radiator hose was moving around a bit I tapped a bolt into the cross member and added a snug-fit vibration dampening loop clamp from McMaster, part number 3177T59. This also keeps it higher up away from the road.
    Bradley
  23. Likes PeteMeindl liked this post
  24. #223
    Nov 2018
    Centennial, CO
    I mounted the supplied radiator reservoir here. I have to admit I don't know why I've seen this one and a larger one mounted in other build threads, but this is working so far. Maybe it's for additional capacity?
    Bradley
  25. #224
    Nov 2018
    Centennial, CO
    Ah, thank you! I remember now I saw them on his thread last fall. I think that's a snip from his photo. I took it to remind me...
    Bradley
  26. #225
    Nov 2018
    Centennial, CO
    KRC Power Steering
    Power steering installed. I love the design of this pump and reservoir! it fits snugly into the engine and saves space over previous designs I've seen and it's easy to install.
    Bradley
  27. #226
    ATL GA
    The power steering fluid reservoir (if you had that option prior to FFR switching to the current power steering set up) was similar looking but smaller. THat could be what you have seen.
    FYI - I, along with many others went with a moroso coolant tank that allows for factory routing of coolant hoses vs the capped lines that FFR instructs.
  28. #227
    Nov 2018
    Centennial, CO
    OBD II Plug and Indicator
    I mounted my OBD-II plug vertically to hide it. This photo is looking up from the foot box through the pedal box. The second shows that the plug is still quite accessible and the light can be seen from the driver’s seat with a little bending down.
    Bradley
  29. #228
    Nov 2018
    Centennial, CO
    What do you mean by capped? Mine goes from the radiator pressure cap to the fill pipe in the bottom of the reservoir and then an overflow drain line comes out the bottom.
    Bradley
  30. #229
    ATL GA
    What do you mean by capped? Mine goes from the radiator pressure cap to the fill pipe in the bottom of the reservoir and then an overflow drain line comes out the bottom as well
    In stock form there are additional overflow inlets that the FFR tank doesn't accommodate so the instructions have you cap or loop those outlets on the engine. I don't recall anyone having an issue with that route, but many people choose to follow the ford planned routing using an aftermarket tank and hoses. EdwardB details it our pretty nicely:
    https://thefactoryfiveforum.com/show...oso#post220495
  31. #230
    Nov 2018
    Centennial, CO
    Thanks, I'll check that out. I have to admit I haven't been keeping up with the forums - too busy working on the car
    Bradley
  32. #231
    Nov 2018
    Centennial, CO
    Instruments
    Started the daunting task of wiring of the instrument cluster
    Bradley
  33. #232
    Nov 2018
    Centennial, CO
    ...and five minutes later:
    Bradley
  34. Likes PeteMeindl liked this post
  35. #233
    Nov 2018
    Centennial, CO
    Bradley
  36. #234
    Nov 2018
    Centennial, CO
    Did I say minutes? It may have been days, but no real problems here. I blew a few fuses - bought the multi pack!
    I learned what a real sports car was watching my dad manipulate the toggles and knobs on a Jaguar XKE in the early 60's. I love switches and knobs! It's probably what drove me to flying. Anyway, my dash is filthy with gauges, switches and knobs and I love it!
    Bradley
  37. #235
    Nov 2018
    Centennial, CO
    So I’m interested in this steel blue color. I wonder if anyone recognizes it? I found it on a website selling the car https://www.pjsautoworld.com/vehicle...ory-five-cobra
    They just described it as steel blue metallic.
    Bradley
  38. #236
    Nov 2018
    Centennial, CO
    Can anyone tell me what these are? They came in the Coyote install kit I bought a while back, thanks.
    Bradley
  39. #237
    Central Lake, MI
    Bottom is the Coyote pedal mount. This is relatively new and gets the pedal even with the others.
    MKIV #9542 Complete Kit, Coyote, IRS - Delivered - 2/19/19, First start - 9/8/19, Go Cart - 9/14/19
    1965 Mustang Convertible 4v 289
    Build Thread HERE
  40. #238
    Nov 2018
    Centennial, CO
    Quote Originally Posted by Cruzzz View Post
    Thank you. I have been stumped by that one for some time. Either I missed something, or they don’t tell you that in the Coyote install manual. I guess I should have checked sooner - I ended up fabricating my own.
    Bradley
  41. #239
    X2 on the Coyote pedal mount. The other part is intended to mount the Power Distribution Box (PDB). Depends on where you mount it whether you need the bracket or not. The PDB has mounting ears and I've mounted them directly to the firewall without anything additional.
  42. #240
    May 2018
    Park City, Utah, USA
    Hi GT - loved your 5 minutes til the dash was done! I think that top piece you're asking about is to mount a box that's part of the coyote wiring harness on top of the passenger footbox. It's shown on page 67 of the coyote fitment manual (version 9/5/18). You're making great progress!!
