04-01-2019, 10:45 PM
#201
Fixit
Yup... it's all cylinder head.
Curious... what are your clearances PS & DS to the footbox tin?
A full inch on the PS foot box. As little as a quarter inch on the drivers side. It’s a half inch on average, but at the bolt bump out it’s a quarter. Is that common?
Bradley
04-02-2019, 05:02 PM
#202
That's just about exactly what I wound up with.
John D. - Minneapolis 'Burbs
04-10-2019, 06:07 PM
#203
Can anyone help me with identifying which harness this Intercooler wire is in?
Bradley
04-10-2019, 06:52 PM
#204
GTBradley
Ford Coyote control pack harness.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
04-10-2019, 07:22 PM
#205
Does it really need to be cut back, because I can't find it.
Bradley
04-10-2019, 07:45 PM
#206
GTBradley
No, it doesn't hurt anything to be there. But a little strange you can't find it. It's item P on the control pack harness, per the Ford instructions.
https://performanceparts.ford.com/do...-6017-504V.pdf
Build Thread and
Video.
Build Thread and
Video
04-10-2019, 09:57 PM
#207
Ah, thank you. I totally forgot to download that from Ford. I have been using the FFR Coyote Installation instructions exclusively to try and locate it. Everything has been fine until this FFR picture came up. I had identified the right wire on my own, but apparently the FFR picture is old because it shows the wrong colors and that threw me. You've got me back on track once again.
Bradley
04-10-2019, 10:27 PM
#208
Paul, while you're at it, would you give me your thoughts on this location for my overflow tank? I know you didn't use the FFR tank, but do you think this location will work regarding hood hinges, etc? I can't go more aft as the engine is so wide, so I think I'm stuck with this side of the brake line or a different tank altogether.
Bradley
04-11-2019, 06:16 AM
#209
GTBradley
The front to back location will clear the hinges OK. Just watch the height. The gas shock for the hood drops down exactly into that area. Keep it below the bottom of the 3/4-inch hood surround tube (including with the cap) and you'll clear the gas shock.
Build Thread and
Video.
Build Thread and
Video
04-13-2019, 06:16 PM
#210
So the Ford Controls Pack Instruction Sheet says the AC wires come off Takeout CCA, but their picture does not look like what I have. I'm assuming these (pictured below) wires are the same thing. Can anyone with Coyote confirm please?
These are coming from Takeout CCA, along with the fan wire and starter lead.
Bradley
04-13-2019, 10:23 PM
#211
Per the Ford Performance Gen 2 Coyote Control Pack instructions, and my memory, the wires you're picturing here are from the 16-way I/P Pigtail cable. Not the main wiring harness. If those are really in the main harness, then something has changed. i know Ford Performance has made some changes with the later versions of the Control Pack. Later than the Gen 2 version I installed. If that's the case, maybe call the Ford Performance help line. Unless someone else on here has experience with a later version.
Build Thread and
Video.
Build Thread and
Video
04-13-2019, 10:57 PM
#212
You got me to thinkin...I needed the M50A 2017 tech sheet. Those wires I was asking about are intended for Electric Power-Assisted Steering (EPAS) and this one does not have the option for A/C.
Bradley
04-14-2019, 06:23 AM
#213
GTBradley
There you go. Hadn't seen that update, but shows some of the changes I've heard about. Nothing that should affect anything with your build. Just different.
Build Thread and
Video.
Build Thread and
Video
04-14-2019, 09:49 AM
#214
edwardb
In fact, everything had been identical til the A/C wires were missing. Don’t know why they would omit those, but I hadn’t planned on air conditioning here in the mountains anyway.
Bradley
06-03-2019, 07:18 PM
#215
Well, it's been a couple of months again since I updated the thread with details, so I'll try to catch it all up again.
Bradley
06-03-2019, 08:21 PM
#216
Only minor scratches to the frame, but we apparently broke the LS O2 sensor plug. It still works and makes a good connection, so I have it zip tied to stay together. I'm not sure how to go about replacing it.
Bradley
06-06-2019, 09:38 AM
#217
Transmission Spacers
I made my spacers - three of them out of 1/4" aluminum plate I ordered from Amazon.
Longer bolts were needed and 7/16" -14 by 1.5 inches long worked.
Bradley
06-06-2019, 09:46 AM
#218
3/4" of lift provided by the spacers seems to align the transmission with the center sect just fine.
Bradley
06-06-2019, 10:09 AM
#219
I found this badge online some time ago and can't remember where. I really like it but I don't know who sells it. Does anybody know?
Bradley
06-06-2019, 11:06 AM
#220
Engine Bay Fuel Line Routing
Routing the fuel line in the engine bay
The fuel line for this setup has no return line in the engine bay, and the regulator is back at the fuel tank so this is super easy and clean. As a result, the vacuum line that would go to the fuel regulator is capped at the engine.
Bradley
06-06-2019, 12:44 PM
#221
GTBradley
Wareaglescott has them. I believe he got them from https://www.billetbadges.com/
06-06-2019, 12:48 PM
#222
Radiator Mounting - Breeze
Radiator installed using Breeze upper and lower mounts. The piano hinge makes setting the correct angle a...well...let's just say it, a breeze.
Breeze fan shroud and radiator stainless hoses:
Because the lower radiator hose was moving around a bit I tapped a bolt into the cross member and added a snug-fit vibration dampening loop clamp from McMaster, part number 3177T59. This also keeps it higher up away from the road.
Bradley
06-06-2019, 01:02 PM
#223
I mounted the supplied radiator reservoir here. I have to admit I don't know why I've seen this one and a larger one mounted in other build threads, but this is working so far. Maybe it's for additional capacity?
Bradley
06-06-2019, 01:20 PM
#224
Jdav
Ah, thank you! I remember now I saw them on his thread last fall. I think that's a snip from his photo. I took it to remind me...
Bradley
06-06-2019, 01:28 PM
#225
KRC Power Steering
Power steering installed. I love the design of this pump and reservoir! it fits snugly into the engine and saves space over previous designs I've seen and it's easy to install.
Bradley
06-06-2019, 01:29 PM
#226
GTBradley
The power steering fluid reservoir (if you had that option prior to FFR switching to the current power steering set up) was similar looking but smaller. THat could be what you have seen.
FYI - I, along with many others went with a moroso coolant tank that allows for factory routing of coolant hoses vs the capped lines that FFR instructs.
06-06-2019, 01:47 PM
#227
OBD II Plug and Indicator
I mounted my OBD-II plug vertically to hide it. This photo is looking up from the foot box through the pedal box. The second shows that the plug is still quite accessible and the light can be seen from the driver’s seat with a little bending down.
Bradley
06-06-2019, 02:35 PM
#228
Jdav
What do you mean by capped? Mine goes from the radiator pressure cap to the fill pipe in the bottom of the reservoir and then an overflow drain line comes out the bottom.
Bradley
06-06-2019, 03:04 PM
#229
GTBradley
What do you mean by capped? Mine goes from the radiator pressure cap to the fill pipe in the bottom of the reservoir and then an overflow drain line comes out the bottom as well
In stock form there are additional overflow inlets that the FFR tank doesn't accommodate so the instructions have you cap or loop those outlets on the engine. I don't recall anyone having an issue with that route, but many people choose to follow the ford planned routing using an aftermarket tank and hoses. EdwardB details it our pretty nicely:
https://thefactoryfiveforum.com/show...oso#post220495
06-06-2019, 03:51 PM
#230
Jdav
Thanks, I'll check that out. I have to admit I haven't been keeping up with the forums - too busy working on the car
Bradley
06-06-2019, 03:54 PM
#231
Instruments
Started the daunting task of wiring of the instrument cluster
Bradley
06-06-2019, 03:55 PM
#232
...and five minutes later:
Bradley
06-06-2019, 03:58 PM
#233
Bradley
06-06-2019, 04:11 PM
#234
Did I say minutes? It may have been days, but no real problems here. I blew a few fuses - bought the multi pack!
I learned what a real sports car was watching my dad manipulate the toggles and knobs on a Jaguar XKE in the early 60's. I love switches and knobs! It's probably what drove me to flying. Anyway, my dash is filthy with gauges, switches and knobs and I love it!
Bradley
06-09-2019, 10:15 AM
#235
So I’m interested in this steel blue color. I wonder if anyone recognizes it? I found it on a website selling the car https://www.pjsautoworld.com/vehicle...ory-five-cobra
They just described it as steel blue metallic.
Bradley
06-10-2019, 05:54 PM
#236
Can anyone tell me what these are? They came in the Coyote install kit I bought a while back, thanks.
Bradley
06-10-2019, 07:12 PM
#237
Bottom is the Coyote pedal mount. This is relatively new and gets the pedal even with the others.
MKIV #9542 Complete Kit, Coyote, IRS - Delivered - 2/19/19, First start - 9/8/19, Go Cart - 9/14/19
1965 Mustang Convertible 4v 289
HERE
06-10-2019, 09:46 PM
#238
Cruzzz
Thank you. I have been stumped by that one for some time. Either I missed something, or they don’t tell you that in the Coyote install manual. I guess I should have checked sooner - I ended up fabricating my own.
Bradley
06-11-2019, 06:02 AM
#239
X2 on the Coyote pedal mount. The other part is intended to mount the Power Distribution Box (PDB). Depends on where you mount it whether you need the bracket or not. The PDB has mounting ears and I've mounted them directly to the firewall without anything additional.
Build Thread and
Video.
Build Thread and
Video
06-11-2019, 08:19 AM
#240
GTBradley
Hi GT - loved your 5 minutes til the dash was done! I think that top piece you're asking about is to mount a box that's part of the coyote wiring harness on top of the passenger footbox. It's shown on page 67 of the coyote fitment manual (version 9/5/18). You're making great progress!!
