Results 1 to 5 of 5
Thread: Mk4 Rear Upper Control Arm Rear Bolt Nut
    Just starting my kit. I could get to the nut on the backside of the front upper control arm nut, however the rear nut seems like there isn't enough space between the frame and the nut to get to it. I tried a socket and it wouldn't fit. I thought an open ended wrench might fit but there just is no angle for it. The edges of the nut actually catch on the frame when I turn the bolt. Anyone else have this issue or anyone have any ideas?
    Mine were tight, but I could put an end wrench on both.
    Could you possibly use a Crows Foot Wrench to get in there?
    If not, then you really need to contact Factory Five's Tech Team one of the Master Builders who are major contributors to this forum give you some suggestions.
    #9160 BB767's Avatar
    Chehalis, WA
    Quote Originally Posted by robotheman View Post
    I had the same problem. After much consternation I turned one of the flat sides of the nut parallel with the frame then inserted a steel wedge between the two. I then torqued the bolt. This may not be the ideal solution, but I was able to get it as tight as it needed to be.
    MK4 - complete kit - Blueprint 427W - Holly Sniper EFI - TKO 600 .64 - 3.55 3 link - 17" Halibrands
    Senior Member luvaz's Avatar
    ...and if it helps any, that 'steel wedge' mentioned above can be as simple as a flat tipped screwdriver. Don't over-think it!
    HTH,
    Will
    FFR MK III picked up 9/24/05 Roller 9/28/05 First start & go-cart 11/28/05 red w/white stripes, PC Chassis, heat/defrost, FFR 15's, pwr footbox vents, radio delete, dual quad 427W, 4 link w/3.27's, Koni's all around, Gen 1 rag top, snapless tonneau, Herb's door panels, NRC rear discs, Breeze head rest, ********** emblems, Paint by Gino's in Rowley, MA
    2011 ffcars.com calendar Cover Car Yes, that's me in the avatar with Dave Smith in front of my roadster at the '06 FFR Open House!
    JohnK's Avatar
    Sep 2018
    SF Bay Area, CA
    I was able to stick the end of an open-ended wrench in there perpendicular to the nut and hold it while I tightened it.
