Results 1 to 6 of 6
Thread: New Member Gurnee, IL (Chicago) FFR Roadster
    Senior Member nuhale's Avatar
    Jun 2019
    Gurnee, IL
    Pulled the trigger on a partial build 2010 MK4 a little over a month ago. Deal was too good to pass up on and glad I did. Original owner spared no expense with options. So far everything been going well and have been spending a TON of time researching these forums for my planning phase. It awesome to have such a great resource to help me along in this journey.
    Spent the last few weeks going over the build so far and only thing I've had to correct is the U/L Control arm and tie rod dust covers. Thanks to the forum was able to identify better system with the energy suspension 5.13102G set. Much more in the works including my Gen 2 coyote I've been talking to Mike Forte on.
    I'm an Engineer and really looking forward to see what kind of trouble i get myself into as I tend to go overboard in perfection in just about every project I get into. Looking forward to the road ahead!
    Bryan Hale
    Welcome aboard. If you like to go overboard on your projects you've come to the right place. You are in for a great ride. Look forward to following your progress.
    Senior Member Robodent's Avatar
    Aug 2018
    Hampshire, IL
    Welcome!!! Have fun with your build . I’m in hampshire Il not to far away building a 35 truck. Good luck to you. Rob
    Senior Member gtaroger's Avatar
    Trenton Mi
    Welcome to the forum. We are happy to help you spend your money. Roger
    Dec 2014
    Gurnee, IL
    PM sent
    #8619. Picked up 5/27/15, First Go Cart 7/16, Finally Legal 5/18
    BadAsp427's Avatar
    Greeneville, TN
    Welcome to the madness. You are in the right place... Need an answer, just ask this forum... the answers are here...
