Thanks Thanks:  3
Likes Likes:  10
Page 1 of 3 123 LastLast
Results 1 to 40 of 110
Thread: Replacing the fuel pump on my MKIII - On the road again!
    My fuel pump is kaput. I am starting the process of replacing it and have a few questions:
    I have a full tank of gas. Is siphoning my only option to lose some fuel? If so I guess I should buy som surgical tubing and try not to inhale gas?
    Is cutting an access hole an option or am I asking for an explosion? Is covering the tank with a moving blanket before cutting wit a dreamer an option?
    If I do cut I’ll need measurements. Does anyone have them handy?
    If I cut, should first remove the tank entirely? Would the existing exposed gas line become a hazard at that point?
    Any other issues I should consider?
    "The I.E." SoCal
    Just tried calling you. I have some advice and I think I have a couple fuel pumps if you are in need.
    __________________________
    Its just like doing it in the mustang that the tank was designed for. Hopefully, with no access panels, you left the lines and electrical loose enough to drop the tank.
    Either siphon a bunch of gas out or get a few friends to help balance it on a jack and a piece of wood. Undo the filler and the straps and lower it down, detaching the fuel lines and the electrical as soon as you can access them.
    I know an access panel breaks up all that beautiful metal, but with a panel, the whole job would take about 30 minutes. Maybe put one in while the tank is out?
    [edit: that tank, when full, is about 100 lbs and really, really awkward. Make sure you get help.]
    I agree w/ Boyd the tank is especially awkward w/ gas in it. I ran mine down to 1/4 tank when I wanted to remove it and I am not sure that is better. Turns out that with just a one degree slope, as you maneuver it, all the gas runs to one side. Now it's awkward and unbalanced. Mine slid off the small piece of plywood I had on the floor jack pad and came out of the car real fast. So I'd cut an access hole first. Your tank filler is capped. Do you have a hose coming off the tank vent? If so plug it temporarily. If not install one and plug it. I would do it at zero dark thirty so the gas is as cold as it will get and giving off the least amount of vapor. For in place aluminum I really like my multi tool
    https://www.homedepot.com/p/Dremel-M...5-01/305884644
    I use a half round blade installed about 45 degress so a lot of it's cutting edge is on the side. I find I can cut super straight lines this way.
    So. Bay (So. Calif.)
    For siphoning, by far, hands down, the greatest invention ever. (Why didn't I think of it.).
    https://smile.amazon.com/SUYIZN-Siph...-1-spons&psc=1
    Stick the ball bearing end in the tank, shake it up and down a few times, (I know, pretty suggestive...) and WAH-LAH! Gas flows out.
    David,
    After you Yank-Da-Tank and have access to the locking ring remember to use a Brass Rod if you need to knock/tap that sucker loose.
    Sparks suck and a partially full gas tank is a bomb as we all know and we don't you to go up in smoke like the fireworks that we'll be blowing up on Thursday.
    Thanks guys. And thank for the lead on the siphon. They sell this at my local pep boys so I’ll pick one up today.
    I agree that I’m dealing with a potentially explosive situation so I’m not going to cut the access hole with the tank n the car. I will report back after it is dropped. If I do cut it after I might need some measurements from those who have the hole cut at the factory.
    Senior Member SJDave's Avatar
    Santa Clara, CA
    Have a couple fire extinguishers at the ready with another friend standing by just in case.
    Move the car outside
    Don't forget to disconnect the battery
    Wear only natural fibers clothes...no polyester
    A near empty tank is the most dangerous from explosion point of view
    Good luck be safe!
    Lilburn, GA
    David, the fumes are more dangerous then liquid gas. You can light a small open container of gas and it will burn like a candle. A closed container of fumes is like a hand grenade. As Steve (Go-Dad-Go) said use brass to not have a spark.
    As SJDave said - do it outside.
    Is cutting an access hole an option-----NO
    Today I managed to CAREFULLY drop the tank:
    Then I disassembled the pump from the carrier:
    The screen was a lot dirtier than I anticipated. How do I clean it?
    One thing I could not figure out was how to get the filter off the bottom of the pump. I didn't want to force it. Do these pumps look compatible to you?
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    The screen is disposable, throw it away. The new pump should have come with a new one. If you want to remove it, a flat blade screwdriver can be used to pry it away from the bottom of the pump.
    The pumps look similar. The rubber isolator from the old pump can be fitted around the new pump.
    Thanks Frank! I didn’t see a new filter. Going outside to check it out now...
    No filter included with the pump. The screen on the old pump looks like it’s locked on. I’ll call Fortes’s in the am.
    Maumee, OH
    While you've got the tank out, it's time to cut that access hole. Use some nut-serts and make it easy to remove in the future. You'll obviously need some aluminum to make a cover panel, but the good thing is, you get to decide how big to make it rather than using what FFR provides.
    Scott
    May 2019
    You can use rubbing alcohol on that screen to clean it up. I would probably just dip it into some and let it sit there for a bit. Good work on getting the tank out. I remember that being awkward when it was empty. I hope to never need to do it with fuel in the tank.
    Aug 2018
    OK Mr Hodgkins
    Did you drain the tank or just man handle it full?
    Quote Originally Posted by Jetfuel View Post
    OK Mr Hodgkins
    Well... I am a Wookie... -jk
    I think the tank ended up being less than 1/2 full. Once I got everything loosened up and the fuel lines separated I put a set of jackstands under the tank and had my daughters stablize the tank while I lowered it to the jackstands. At that point I disconnected the electrical for the pump and sender, then I raised it up, pulled the jackstands, and lowered it to the ground, again with the help of my daughters.
    From there I muscled it outside and siphoned the gas out using the jiggle siphon mentioned above.
    I'm waiting on a new filter from Mike Forte. I might have to cut the rubber isolater bottom because it looks like the pump have different positions at the bottom for the filter. Once I get the filter tomorrow I'll post more pics and an update.
    The Moral Of The Story:
    You Can't Beat Those Wrench Passing, Tool Handing, Ratchet Swinging Tank Grabbing Baby Girls!
  19. Likes Jetfuel, David Hodgkins, RBachman liked this post
  20. #19
    I received a new fuel pump screen today - Thanks Mike Forte!!
    I'd like to create access holes for the sender and pump before reassembling. Can someone supply the measurements? I need width, length, and location info...
    Anyone?
  21. #20
    i.e.427's Avatar
    Nov 2016
    "The i.e." SoCal
    Anyone?
    Call me tomorrow and I can measure while on the phone.
    RJD's Avatar
    Northern Virginia
    I'm not at home right now so I can't run out to the garage and measure, but perhaps these photos will help you estimate.
  23. #22
    Frank will probably tell you the same but make that hole as large as possible to provide plenty of working room because even when the tank is on the ground it often takes a lot of wiggling and various approach angles (as well as creative swearing) to get the pump and pickup around the internal baffle and into position. Oh, one other thing...don't forget to put the gas back into the tank before you lift it up into place
  24. Likes Jetfuel liked this post
  25. #23
    Lost Wages, Nevada
    Dave,
    Can't agree more . . . make the hole(s) as big as possible, especially for the pump. It needs a lot of "wiggle room" to get it in to the tank if the trunk floor is still above it - pretty simple if the tank is on the floor.
    Grease the gasket "O" ring when re-installing the pump mount - use a non-metal drift punch to tighten the retainer ring . . . we don't want any sparks to get to the fumes coming out of the tank during pump install.
    Doc
  26. #24
    I think I'l take all y'alls advice and make it oversized. I pulled the pump from my brother's car and remember what a pain it was. I might try to copy RJD's design. RJD, I like that size you created. Good job!
    Doc, thanks for the reminder. I'll take care putting the retainer ring back in.
    Now where did I put that flint hammer???
  27. #25
    Super Moderator
    Ray's Avatar
    La Mesa, California
    This is the one BIG reason that I went an external fuel pump!
    Ray
  28. #26
    Today I worked on drilingout the access holes for the fuel pump and the sender. Here are some pics of how I measured and drilled the holes:
    2-3/4" from the center of the outer strap, r=then I added an inch and rilled a 4" hole:
  29. #27
    Then I added the corners using a 1-1/4 radius drill and cut out the shape:
    Next,I added a 4" hole 17" from the original measurement of the fuel pump hole (minus the 1: offset)
  30. #28
    Lost Wages, Nevada
    As usual, you are showing off your sheet metal working skills . . . the master at work.
    Looks GREAT! Dave.
    Doc
  31. #29
    I have a problem:
    The rubber sleeve I'm attempting to use off the old pump has a thick bottom that is preventing me from attaching the filter.
    Can I just cut off the bottom of the sleeve?
  32. #30
    Bad news. After replacing the pump I turned the key to test it and nothing happened. So I’m back to testing the I Squared harness.
  33. #31
    Aptos, CA
    What made you think the old pump was bad in the first place? Did you test the pump direct before you pulled the old one out?
    www.weendoggy.com/cobra.htm
  34. #32
    Nope. Live and learn I guess.
    I think the relay went bad. There is an indicator light on the board that isn’t lighting. I thought maybe it was because the connection wasn’t made at the pump but I guess I was wrong. That stopped making that relay in 2014.
    Frank (ie427) mentioned there is a stand alone module that I could replace it with. I’d have to figure out a way to wire it.
    That’s what I get for going non traditional with the wiring harness...
  35. #33
    Senior Member KDubU's Avatar
    Kennebunkport, ME
    David failed???? What up with that? Built two roadsters and a fuel pump beat you?
    Kyle
  36. #34
    Las Vegas, NV
    Dave,
    What is the manufacturer and part number of the relay?
    Allan
  37. #35
    Bakersfield, CA
    Dave, someone posted some diagrams on your original relay swap post (which for the life of me I can’t find again and no idea how I found it in the first place) of the discontinued relay. The pin configuration, 86,87, 87a etc is the same as every 80’s to mid 90’s BMW used. Basic Bosch relay. BMW dealer, import car part place that maybe deals in old VW’s,amazon? (That’s where I got the pictures) The only difference might be the Panasonic blades might be narrower? Hard to tell but nothing a pair of dykes couldn’t handle lol Or a bigger ford tool We build, we modify...and as the dark side always says...
    we persevere lol Panasonic, Bosch, tomato, tomahto.... easy peasy
    Most of the Bosch relays have a diagram on them that you can match to what that guy posted in the specs picture. It might even be on your bad relay? Match up the PIN numbers, diodes, resistors etc and your good to go. Oh and hopefully the pin spacing would be the same. If not still totally modifiable.
    HTH
    Kurt
    Build thread
  38. #36
    Bakersfield, CA
    Oh but on the plus side of it all Dave.....
    You have a new access hole!!!
    Build thread
  39. #37
    Kurt, are you talking about this thread?
    https://thefactoryfiveforum.com/show...the-road-again!
    Allen, the relay itself can be found here:
    https://www.mouser.com/datasheet/2/3...14-1075658.pdf
    It is the #3. Micro-ISO PC board type (1 Form C)
  40. #38
    Las Vegas, NV
    Dave,
    Is the relay plug-in or solder-in? I can't quite tell from the Mouser reference. If plug in, there are several vendors on eBay selling NEW Panasonic CM-1a relays. Go for one without the "R", which has a built in resistor. If solder, let me know, maybe I can find something else in the same form factor.
    UPDATE: I looked at the data sheet a bit more carefully; see below:
    Can you send me the EXACT P/N from the relay? From the data sheet, it appears that the only solder-in relays were 24v, not 12v. If so, the relays being sold by the following vendor would work perfectly: https://www.ebay.com/itm/NEW-CM1-12V...YAAOSwFMZWqg3V
    Also, the only discontinued ones are the ones with the diode, which is typically installed ACROSS the coil of the relay to dampen eddy currents (created during on/off, sort of like back EMF).
    Allan
  41. #39
    Allen it's the solder in type AC13111.
  42. #40
    Las Vegas, NV
    Dave,
    Those are the same relays you swapped before, and NOT the ones on the Mouser page you sent me. I'm confused now.
    UPDATE: Assuming this is from the same board you repaired before, the part number for the fuel pump relay is CB1-D-P-12v; ebay link is as follows:
    https://www.ebay.com/i/142407957227?chn=ps
    Allan
