Thread: Selling 05 STi
    Selling 05 STi
    2005 Subaru WRX STi Race Car
    23k miles on chassis (80% freeway, 5% city, 15% track)
    Full NASA legal cage.
    Driver and Engine fire suppression
    Mod Listings:
    Engine:
    Cobb Access port v1 with 91oct map and 100oct map. Both in realtime and full versions.
    X-racing? (don't remember the name) large top mount intercooler
    K&N air filter
    Custom downpipe (Helix Catted downpipe, with the cat removed)
    TGV's removed
    Ported and polished and coated stock exhaust headers
    Walbro 255 fuel pump
    Engine Oil Cooler, one of the first things I installed. (Engine burns almost no oil at all)
    Stock air box with silencer removed
    Drive train:
    JDM 5th and 6th short ration gears installed
    Alcon 340mm 2 piece rotors
    Alcon 4 piston front calipers
    Racing Brake rear 2-piece rotors
    Stainless steel brake lines
    ACPT Carbon Fiber Driveshaft
    Perrin Lightweight engine pulley
    Racecomp engineering brake duct mounting pieces
    Front and rear bearings replaced relatively recently. Fronts changed to rally spec bearings
    ACT 6 puck, sprung, racing clutch
    ACT Prolight flywheel
    Suspension:
    Whiteline 27-29mm front swaybar
    Whiteline 22-24m rear swaybar
    Whiteline adjustable swaybar endlinks
    Whiteline Anti-Lift Kit
    Whiteline Ball Joint Extenders
    Racecomp Engineering Tarmac2 coilovers with 600lbs front and 500lbs rear springs
    Racecomp Engineering lowering front camber plates
    Cusco Rear Camber Plates
    Aero:
    Custom splitter
    Custom full body under-tray
    Custom diffuser
    Carbon Fiber Trunk
    Brake Ducts
    Brake Duct fans
    Other:
    JDM Lightweight 2mph front bumper beam
    Lightweight Battery
    Momo racing wheel with quick release
    Main Battery kill switch
    Cusco underbody brace
    Car-Labs x-brace
    Turn In Concepts fender Cowl Braces
    Defi Boost, Oil Pressure, and EGT gauges
    Defi Gauge controller box
    Two sets of Rota wheels, i don't remember what kind off hand. 17x9
    New Standard Equipment:
    New master brake cylinder.
    Nearly new VF43 turbo, 1000 miles used. Basically same as the VF39 except for a larger wastegate.
    Transmission just refreshed with new syncros
    Car Weight with 1/3 tank of fuel: ~2925lbs (depending on what is done, maybe another 100lbs can come out)
    Dyno info: No current info but around 265-270whp/305wtq on the GST Dyno 91 oct. 100oct estimated between 300-310whp/350wtq.
    Fire suppression system installed
    Oil Used: Valvoline 20/50 Full Synthetic changed ever other outing
    Salvage title.
    Vehicle is currently in storage, oil still being change and car still being run.
    Video of the car running:
    https://photos.google.com/share/AF1Q...xyUXlVWWhiS0xR
    $9,000
    Listed as non-op. No back fees.
    Let me know if you have any questions.
    Evan Mironov
    415-260-0834
    Sgt.Gator's Avatar
    Bend, Oregon
    Looks interesting.
    Why the salvage title?
    Is it running now?
    Is there a wing?
    Located in San Francisco?
    You need way more pics, is it listed somewhere with more pics?
    Owner: Colonel Red Racing
    818R ICSCC SPM
    I have a friend who is an insurance adjuster, and our best guess for the salvage was that it was rolled over. (We based this off a few repair marks based off of the front roof.) I really don't know exactly why it was salvaged. I bought it already rebuilt. I think it had around 6,000-8,000 miles on it when I got it.
    The car is running. I think I took the video above in December 2018.
    No wing. Use for another project, it was a cheap ebay wing anyways.
    Car is currently located in Truckee, CA.
    In addition to the video above, these are the pictures I have on me: https://drive.google.com/open?id=1Rr...8qym2ouIhhJ4_M
    Sgt.Gator's Avatar
    Bend, Oregon
    Truckee! Hmm, I've been thinking about visiting the Carson City - Minden - Gardnerville area anyway as a future residence to get away from the nuttiness and taxes of Oregon. I may have to add Truckee on the trip down.
    818R ICSCC SPM
    Bowling Green, KY
    Gator, Bowling Green is a nice place and we have shop space available at the track.
    This STi would be a great option for anyone interested in either a built car or using for an 818 kit.
    The car has to go ASAP.
    Moving to classifieds...
