Oh Tim, you know that was my first thought ! I know it's difficult to see in the original picture I posted, but it should be a little more clearer in the one shown below...The star would have to have a bend in it and because of very little clearance between the shifter park position and the bottom of where the radio will sit, I would have to skew the star (it would be wider than tall). For that reason alone, I decided to just keep it clean and simple (this should also make the stitching for the shifter boot not be so challenging. With that being said...any true Cowboy fan knows that a teardrop typically makes its appearance on several occasions during a season !
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
wrp liked this post
