London Cobra Show
Likes Likes:  30
Page 13 of 14 FirstFirst ... 311121314 LastLast
Results 481 to 520 of 536
Thread: Andrew's 818S - LYTW8
  1. #481
    USA
    New low mount turbo kit work has begun. This time with a single scroll EFR 7163 and external wastegate.
  2. Likes Hobby Racer, Mitch Wright liked this post
  3. #482
    Syracuse, NY
    Looking good. I was linking of mounting small twin turbos on my H6 in a similar location one on each bank! Where are you sourcing the tubing and turbo flange?
    MK3.1 Roadster completed 2011
  4. Likes Mitch Wright liked this post
  5. #483
    Atlanta, GA
    What's the reason for low mounting the turbo? Shorter exhaust plumbing before the turbo to reduce lag?
  6. #484
    south-central CT
    Interesting. My plan for a low-mount is to put it in front since I'll have a fuel cell.
  7. #485
    USA
    I've sourced flanges from all over the place. 1/2" 304 stainless machined to accept 1.5" schedule 10. One example:
    https://www.pandlmotorsports.com/sho...t-head-flange/
    Your choices for the H6 may be limited:
    https://www.racemufflers.com/Subaru-...-80047-shf.htm
    Sch 10 tubing can be found all over the place. Amazon, aceraceparts.com, Vibrant, etc.
  8. #486
    USA
    Quote Originally Posted by lsfourwheeler View Post
    Pretty much.
  9. #487
    USA
    That was last year's setup. Been there, done that.
    Packaging is not particularly fun. I had to move a frame cross brace. In the end you've got a heat source right by the low pressure passenger area. The low pressure sucks in heat from all sources. Even with exhaust wrap, extra aluminum heat shield, and turbo blanket the additional turbo heat was noticeable.
  10. #488
    USA
    The manifold mock-up is almost complete. I need to tack up the turbo inlet pipe and v-band. Also need to weld in the wastegate. So close...
    The car has been running an equal length twin scroll setup since 2016. I think this being so uneven should bring back the boxer rumble.
  11. Likes biknman, Mitch Wright liked this post
  12. #489
    How does your design take into account different thermal expansion related to different materials and different temperatures between the engine and the headers?
    https://www.engineeringtoolbox.com/l...ents-d_95.html
  13. #490
    USA
    Quote Originally Posted by UnhipPopano View Post
    I was just talking with lance corsi about this. The flanges have enlarged holes. Slip joints or flex joints could be added. However, if you look at most sch 10 manifolds for Subarus, nothing more than enlarged holes are used.
  14. #491
    USA
    Design is complete. The oil feed line will be re-routed so it is between the manifold and the engine. Now it's time to weld everything up.
  15. #492
    Bowling Green, KY
    Looks awesome and excited to hear the report on performance. It sure has to clean up the engine bay up top.
  16. #493
    Moonlight Performance
    Hindsight's Avatar
    Atlanta
    So much craftsmanship on this build! Really makes me miss my garage!
  17. #494
    USA
    Thanks guys! It's getting close to roadster weather in Michigan. I need to keep cranking.
    At least the other cold weather project is back together. My EFR7163TS + AWIC setup in the Saabaru.
  18. Likes DSR-3 liked this post
  19. #495
    USA
  20. Likes Shawn818c, longislandwrx liked this post
  21. #496
    USA
    My 818 had its first start today on the new turbo. A few loose ends to button up and it'll be ready for tuning.
    The headlight modification is moving along too. The passenger side is ready for fiberglass.
  22. Likes Zach34, Rob T, Mitch Wright liked this post
  23. #497
    Feb 2019
    Houston, TX
    I looked back a few pages and didn’t see any mention, which headlight are you going with? I’m headed down that path now with the old nose, and I gotta say it looks way easier when the headlight is contained within one panel instead of where 3 meet. Definitely making me consider a clamshell.
  24. #498
    USA
    2007-2008 Yamaha R1 Headlights.
  25. #499
    USA
    Rethinking my headlight choice...
    Let me know what you think compared to the R1 headlights.
  26. #500
    Apr 2019
    I like it! What headlight is this one?
  27. #501
    USA
    Those are 14-15 Hyundai Tucson Headlights.
  28. Likes Shawn818c liked this post
  29. #502
    Feb 2019
    Houston, TX
    Personally I prefer the smaller Yamaha lights, but everyone will differ I suppose.
  30. #503
    Sep 2015
    Hamersville, Ohio
    It looks like it's sticking out too far. Will it pull in at speed?
  31. #504
    Bowling Green, KY
    Looks really aggressive, I like it.
  32. #505
    Aug 2018
    Chicago
    Have you checked the beam pattern with those mocked up? I had a pair of R1’s from that generation and it felt like a fairly narrow light spread. It was fine for a bike with HIDs installed but may leave you underwhelmed in a car. I’m sure they would look sharp in an 818 though!
  33. #506
    USA
    Quote Originally Posted by Jake From State Farm View Post
    The beam pattern seemed good. And fairly bright with 55W halogen bulbs. I plan to throw in some high wattage HIDs.
  34. #507
    Aug 2018
    Chicago
    Good call. 55W HIDs will make a huge difference. The halogen headlights were the first to go after the usual upgrades (levers, frame sliders, etc).
  35. #508
    USA
    Roughing in the new R1 headlights...
  36. #509
    Sep 2015
    Hamersville, Ohio
    I like it! I was wondering what a sugar-scoop headlight bucket would look like on these cars, kinda like the Datsun 240Z.
  37. #510
    USA
    Headlight modification is nearly complete. Today I applied the first coats of slick sand.
  38. Likes AZPete, lsfourwheeler liked this post
  39. #511
    Feb 2019
    Houston, TX
    Such a huge improvement, great work.
  40. #512
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    Has a 'vicious' look to it. Cool!
  41. Likes Frank818 liked this post
  42. #513
    Aug 2018
    Wicked......
    One thing....if it’s going to be registered they may probably want some kind of yellow side marker since the lights are encased and not visible from the side....don’t bring it up tho...
    Very nice work
  43. #514
    Feb 2019
    Houston, TX
    Really making me re-think my headlight choice.
  44. #515
    USA
    Not for the faint of heart, so I appreciate the positive feedback.
    Quote Originally Posted by Jetfuel View Post
    Wicked......
    Very nice work
    Luckily it's already registered, I've had it on the road since 2015.
  45. Thanks Jetfuel thanked for this post
  46. #516
    USA
    I started blocking the front quarters and body working the windshield surround. The quarters are turning out super nice.
  47. Likes lsfourwheeler, longislandwrx liked this post
  48. #517
    USA
    I've been making slow and steady progress on the 818. Now I've got all winter to wrap up the remaining bodywork modifications, then possibly change paint colors.
    I'm extending the windshield frame to meet right up to the Subaru dashboard.
    My friend and I upgraded our side by sides at the end of summer. I've been modifying mine and it's at 205 WHP, not bad considering it weighs 1900lbs, similar to the 818. Unfortunately, dune trips and fab work on the Can Am took away from 818 time.
    Here's the 3" exhaust I made.
  49. #518
    Puyallup, WA
    Any updates?
  50. Likes longislandwrx liked this post
  51. #519
    Any updates?
    what he said!
  52. #520
    USA
    It's taken me some time to get back after the 818 project. My business took off and other hobbies took priority.
    I had the low mount UEL turbo setup dyno'd. It came out around 500 whp with really quick spool.
    Then, I had an engine fire with my JDM swapped 9-2x and it really turned me off to anything with Subaru engines.
    So, I ditched the EJ255 in the 818. I've been accumulating parts for some time and I started to mock up my K24 last week.
  53. Likes Hobby Racer liked this post
