Results 1 to 13 of 13
Thread: Hood/radiator cowl allignment issues
    Nov 2018
    Scurry Texas
    Been waiting to install radiator due to back ordered AC condenser but wanted to at least get started on fit and alignment and any mods required. Ran into horizontal plane issues when trying to line everything up. When you tilt the radiator so the cowl plane and hood plane line up it moves the cowl back to far. Huge gap. Cant move bottom in due to radiator hitting the two frame bars at bottom.
    When tilting the radiator forward to close the gap it creates a (V) in the horizontal plane that looks like crap. And being the top, hood, grill are going black, proper alignment and flow from one piece to another is critical.
    I can figure three options of which none would be to fun
    1: tilt radiator to close gap and then slit cowl on right and left top. move everything into alignment and glass back together.
    2: tilt radiator to close gap and build up and shape top of cowl to create the proper plane.
    3: Tilt radiator back to proper plane and then extend hood to close the gaps.
    None of these options are very appealing to me. Can anyone help out with something I'm not seeing? How did you deal with this issue. I see in some of the completed pictures they just went with how it fit and did not worry about it.
    Jun 2019
    Whitehouse TX
    Have not got that for yet.
    Senior Member DamnYankee's Avatar
    Port St Lucie, FL
    I struggled with this too. Finally left it with cowl pointing slightly up at front. The others I've seen are the same way. Unless you bend over to purposely look at it, you won't see it.
    Nov 2018
    Scurry Texas
    Quote Originally Posted by DamnYankee View Post
    Did you have AC Condenser? With the condenser it pushes it even farther forward and have to lean back even more
    Port St Lucie, FL
    I have AC condenser and fan shroud.
    I was able to push whole assembly towards engine (as holes in bracket are slotted) and got the angle right. The lower hose is hitting the chassis. I had to cut a few pieces in the fan to allow the shock bolts to clear, but not an issue.
    On hood only had to trim some at rear.
    Nov 2018
    Scurry Texas
    Would you mind taking a measurement straight down center of your hood? I think part of my problem may be that they trimmed to much off and hood is a little short.
    Port St Lucie, FL
    My hood is 35 7/16 down the center.
    Here's another measurement that might help - from tip of radiator cowl bracket to body lip at firewall is 34 1/4.
    Nov 2018
    Scurry Texas
    Thanks for the info. That measurement helps. There is something different with mine. If I try to tilt back to close gap to that measurement the bottom of radiator hits the two angled cross bars. Farthest I can get is 34 3/4. And that's with raising the mounts up on bolts bolts a bit. I'm going to play around with it a bit after I get the condenser and see if I can shorten the stand off bushings. Maybe re drill to raise the radiator up on the grill a little bit.
    Port St Lucie, FL
    Here's how my radiator is mounted. The spacers are 3/4"
    Loveland, CO
    My measurements that Yankee referenced are: hood down the center - 35 7/8" Not trimmed any. Dash front to radiator top bracket - 35 1/4".
    I did push the radiator top as far toward as possible. Also had to trim the fan shroud for upper shock bolts to clear. My hood fit perfectly with radiator more upright vs. tilted back.
    Lower radiator hose is close, but shielded with more split radiator hose for rub protection.
    Ralph
    Aug 2019
    Fort Lauderdale
    I am trying to figure out the best way to mate the the cowl to the grill, additional attachment points / gasket spacer where do I start
    Jun 2018
    payson az
    Quote Originally Posted by bnelson View Post
    I wish mine fit that good. Your's is 100% better already, and I've got countless hours of work into mine.
    Nov 2018
    Scurry Texas
    I got frustrated and ended up cutting the front shroud, aligning and glassing back together. Was a bunch of work but it all fits perfect now. I had a heck of a time getting the shroud to fit against the grill. I ended up adding glass in a couple places to get it to fit flush all the way around. I also drilled and taped holes about 6" apart from top of grill sides down to bottom. Installed rubber headed screws. That way I was able to screw them into required depth to hold the shroud out flush to grill and keep it stationary. There are probably better ways but I was just winging it.
  14. Likes Sbda4 liked this post
