E Brake cable problems
So I was waiting quite a while on back ordered calipers. Got them a couple weeks ago and installed. E brake cables were wrong so they sent new ones. Got those today and went to install. The passenger side fits great but the drivers side is same length and is tight from handle to caliper. I would not be able to strap it down due to required suspension travel. Is this what everyone else has? Seems like drivers side should be 6-10 inches longer due to e brake handle position?
I will have to measure mine. I cannot remember if mine are different or not.
sperger72
Is your drivers side tight? Mine is like a banjo string from Caliper to brake handle.
Mine is not tight at all has crap loads of extra on both sides.
Zach
Can anyone take a measurement on the e brake cable? FFR is saying that the one I have is correct. Mine measures 67" from end of fitting to end of fitting. 5" of cable sticking out. I cant see how that is correct. It is tight from caliper to brake handle with zero slack.
I installed a e stopp. Electric gizmo I didn’t want to deal with the hand brake design .
FFR 35 p/u # 0016 Dart 347 TKO 600
Robodent
Sounds like a great idea. I'll check it out.
Robodent
If you can provide pictures on how it was installed that would be helpful. TY!
Black & Copper #1028 ("The Mistress" according to my wife!
![Wink](images/smilies/wink.png)
Andreas
DC8810E4-A918-4DA5-A7FE-28E94F8A4F16.jpg. I had to fab a bracket to mount it to and the only logical spot was next to the trans on the passenger side
Got email back from FFR. They sent wrong length again. Sending more. Third times a charm! I Hope
