I got the 32 front end with my truck kit and the grille insert doesn’t fit into the fiberglass surround. It’s going to need some fiberglass removed to make the insert drop in. I was expecting some tweaking and trimming, but it seems way off. Has anyone else encountered this? What is the best way to remove material on the inside where the insert drops in? I can’t get it to lay flat enough to even mark it without it moving around because of the odd shape, and it looks like I am going to have to remove a lot of glass on the top and bottom.
