Results 1 to 5 of 5
Thread: Deluxe 32 grille and surround fitment
    Jul 2019
    Anchorage, AK
    I got the 32 front end with my truck kit and the grille insert doesn’t fit into the fiberglass surround. It’s going to need some fiberglass removed to make the insert drop in. I was expecting some tweaking and trimming, but it seems way off. Has anyone else encountered this? What is the best way to remove material on the inside where the insert drops in? I can’t get it to lay flat enough to even mark it without it moving around because of the odd shape, and it looks like I am going to have to remove a lot of glass on the top and bottom.
    Jun 2018
    North Vancouver, BC, Canada
    That will just be the beginning, welcome to the fun. You may even find yourself having to add fiberglass in some places on the body (at least thats the case with the hot rod).
    The approach I'm taking in removing material is as follows
    - cutting the fiberglass for removal of significant large strips
    - grinder with a flap disk for easy to get at areas, inside or outside
    - a drum sander for tweaking and hard to get at areas
    Gen 1 '33 Hot Rod #1104
    Falmouth, MA
    I have the 32 grill for my 33 roadster. The grill fits snug but does not require any mods to the fiberglass. Maybe you got a bad radiator surround? These are built by a lot of suppliers -- I wonder if FFR just out sources these as mine is a different gelcoat than the rest of the body.
    Aug 2019
    Arlington, WA
    Quote Originally Posted by Alaskan View Post
    Alaskan, did you get this resolved? I ask because I ordered the standard grill but they sent me the deluxe grill surround, they are going to send me the correct one and said they do not want this one back. I really don't think I would have a use for it so if you want it I could send it to you if you cover the shipping cost.
    Gary
    Jul 2019
    Anchorage, AK
    I'll send you a PM
    FFR Hot Rod Truck #79
    Gen III Coyote with 6R80 A/T
