Thanks Thanks:  21
Likes Likes:  18
Page 1 of 3 123 LastLast
Results 1 to 40 of 102
Thread: FLFrank's '35 Hot Rod Truck Build
    Senior Member FLFrank35's Avatar
    May 2019
    Viera, FL
    Delivery expected in the 2nd half of July
    BluePrint Ford 306, EFI, automatic trans
    Powdercoat frame, satin black
    7S 28 spline 38.50" driveshaft
    Black leather faced bench seat upgrade
    3-Link rear suspension
    Platinum 6 gauge set
    Sound insulation kit + Dynamat
    Chrome tilt steering column
    EFI in-tank fuel system
    Electric steering
    Air conditioning
    Wood bed kit
    Aluminum interior door handles
    8.8 rear axle housing w/TOP 3-Link
    HR 11.65" rear brakes
    Second brake reservoir
    Diamond-plate firewall
    Open engine compartment
    Anti-lock brake system?
    Wheels: Amer. Racing Authentic Hot Rod Sport Muscle Nitro 5?
    Paint: Probably metallic red (like the SMG truck)
  2. Likes Straversi liked this post
    IMO you should delete the seat track. You cannot move the seat forward or back. It only fits in one location.
    May 2019
    Viera, FL
    Wallace18, thanks for the heads up! I didn't consider that; I guess I'll take that off the order. I was thinking of different sized drivers, possible future owners. I sat in the hot rod at the build school but couldn't get a feel for pedal operation and seat placement. I guess I'll figure it out when the time comes.
    Side note...I see you're in Alachua. I have a Hunter 356, which is/was built in Alachua...Do you happen to work at Marlow-Hunter?
    Quote Originally Posted by FLFrank35 View Post
    No I am retired from GRU. Here is my truck build thread. Feel free to PM me if you have any more questions.
    https://thefactoryfiveforum.com/show...Hot-Rod-Pickup
    Loveland, CO
    Agree on delete seat track. With seat all the way back, it would still be tight for a child.
    Ralph
  7. Thanks FLFrank35 thanked for this post
  8. #6
    May 2019
    Viera, FL
    My kit finally arrived!
    Finally got my truck last Thurs (Aug 1). Did inventory in 3 days; found a few missing parts, but what took the most time was trying to figure out what some parts were...although I learned a lot about the parts. Also, got the engine and trans.
    Took some of the bare-metal parts to the powder coater today...said they should be ready in a day or two.
    Any suggestions on were to get headers for the BluePrint Ford EFI 306 (w e-power assist steering) to mate with the FFR exhaust pipes??
    Sorry, would have posted more photos but some are turned 90 degrees and I can't figure out how to re-orientate them.
  9. #7
    Summit is a good place for headers.
    https://www.summitracing.com/parts/b.../model/mustang
  10. Thanks FLFrank35 thanked for this post
  11. #8
    Apr 2019
    I assume the FL in FLFrank is because you’re in Florida. I’m located just north of Tampa. If you’re close, I can offer help turning wrenches. I’m planning on getting my own kit, but probably a couple years out.
  12. #9
    Nov 2018
    Scurry Texas
    I had some pictures with same issue. You can open them in paint program, rotate and save. Good luck with your truck!
  13. #10
    May 2019
    Viera, FL
    Quote Originally Posted by Salty Chief 35 View Post
    Thanks for the offer. I’m over on the east coast near Melbourne. If you’re ever in the area, stop by and check it out.
    It took me a couple years from considering building my own truck to ordering the kit.
    Senior Member DamnYankee's Avatar
    Port St Lucie, FL
    Hi Frank,
    I'm in Port St Lucie with my truck. Mechanical done, just started bodywork phase.
  15. #12
    May 2019
    Viera, FL
    Quote Originally Posted by DamnYankee View Post
    Hi Frank,
    You’re a little over an hour away...I’ll have to stop by when I get a chance (if that’s ok).
  16. #13
    Port St Lucie, FL
    Yup anytime !
  17. Thanks FLFrank35 thanked for this post
  18. #14
    May 2019
    Viera, FL
    Got the control arms powder coated and assembled...
  19. #15
    Aug 2019
    Fort Lauderdale
    Hey Frank, I'm also in FL - Fort Lauderdale; My kit is due to be shipped next week; similar to yours; other than Blueprint 346 (Carb). manual, fenders etc, Wilewoods, Moser rear end, 18' wires by Wheelsmith.
    Be interesting to compare note as we progress.
    Also wondering about headers
    Good luck.
  20. #16
    May 2019
    Viera, FL
    Sounds good! These headers from Summit were recommended to me...https://www.summitracing.com/parts/bbk-15150/
  21. #17
    BluePrintEngines's Avatar
    Nov 2015
    Kearney, NE
    Following!!! Looking forward to seeing the build!!
  22. #18
    May 2019
    Viera, FL
    Got the shocks assembled. One question for anyone out there...The manual says the front shocks are supposed to be 2.5" shorter than the rear, but mine are all the same length. Did I get the wrong shocks or am I supposed to adjust them to the proper lengths? Thanks in advance!
  23. #19
    Jun 2019
    Whitehouse TX
    I had the exact same question, I never received an answer.
    Zach
  24. #20
    May 2019
    Viera, FL
    Dan Golub from FFR says the truck uses all 4 same size shocks.
    Next question...
    In attaching the 3-link suspension, the manual says attach the lower control arms to the center (out of 3) hole on the frame. I have 4 holes...Which one? Either of the center holes? Depending which ride height I want?
  25. #21
    Next question...
    Yes, just make sure your pinion angle is correct once you are finished before you drive it.
  26. #22
    May 2019
    Viera, FL
    Ok, thanks for the advice! I did eventually notice that the two bottom holes are too small for the bolts, so that narrows it down the the two top holes. I chose the lower one to raise the ride height.
    I had a hell of a time getting the control arm eye-bolts and spacers installed in the frame brackets...it's a VERY tight fit. Still have to install the shocks...Any suggestions on how to make this easier?
  27. #23
    Loveland, CO
    I made a spreader spacer tool out of some threaded rod and nuts and bolts to force the ears out if they were too tight. Had to use them in multiple places on the build: front suspension and rear.
    You have the newer frame, I have the early frame, so I had to follow your first picture.
    Ralph
  28. Thanks FLFrank35 thanked for this post
  29. #24
    You can also use a large crescent wrench to spread the ears slightly.
  30. Thanks FLFrank35 thanked for this post
  31. #25
    May 2019
    Viera, FL
    Thanks for the advice guys!!
  32. #26
    May 2019
    Viera, FL
    Build update
    In August I got the rear installed; still waiting for the calipers.
    The rear cover is leaking. I torqued the bolts like the manual says but I may have to call Moser and get a new gasket
    In September and into October I painted and built the front calipers, and got most of the front-end installed, including the rack.
    I am currently work on applying a diamond-plate layer to the firewall and installing that.
  33. #27
    The last Moser I installed leaked there also. They have a production problem IMO. I had to replace the rear gasket.
  34. Thanks FLFrank35 thanked for this post
  35. #28
    May 2019
    Viera, FL
    I was afraid of that. I guess I’ll call Moser.
  36. #29
    Aug 2019
    Arlington, WA
    I have yet to fill my Moser rear end, what about adding some gasket sealant to the gasket?
    Gary
  37. #30
    May 2019
    Viera, FL
    Talked to Shane at Moser...he said it's possible the cover bolts are too short, or the chrome is not allowing a good seal. May have to grind chrome off of the flange so the gasket can seal properly. He's sending a new gasket...I'll post when I figure it out.
  38. #31
    Port St Lucie, FL
    I had a leak there too. I scraped away the old gasket and used just sealer. Ok now.
  39. Thanks FLFrank35 thanked for this post
  40. #32
    Jun 2019
    Whitehouse TX
    Mine leaks too.
  41. Thanks FLFrank35 thanked for this post
  42. #33
    Loveland, CO
    Mine leaked also. Removed and re-sealed.
    Ralph
  43. Thanks FLFrank35 thanked for this post
  44. #34
    May 2019
    Viera, FL
    Solved the axle leak
    For those interested, I finally solved the axle leak issue...
    First, I replaced the original gasket/sealer with the replacement sent from Moser, and as I was scraping off the gasket and sealer I noticed some over-spray of the black paint. This is the original black paint applied at the factory. It appeared that the paint over-spray (or powder coat) was built up enough that it prevented the cover's flange from properly mating with the axle housing causing the initial leak.
    You can see some on the paint that caused the problem along the edge between the 5 and 6 o'clock positions...
    So I sanded the paint off of the axle housing down to bare metal and I installed the replacement gasket After I tighten the bolts to the minimum torque (25 fl/lbs as stated in the FFR manual) I noticed that the gasket and some sealer squeezed out from the cover, torn near the bolts. My mechanic said that usually happens if the the bolts get over-torqued and the cover's flange gets distorted, which makes sense since the 2 pieces could not form a tight fit and as the bolts were tightened they deformed the cover's flange enough to tear the gasket and push it out along with the sealer.
    My mechanic hammered the cover's flange at the bolt-holes so the entire flange was flat. I applied a new gasket and sealer and torqued the bolts to the minimum 25 fl/lbs. Between the smooth and level surfaces it seems that I finally have a tight seal and stopped the leak.
    Hope this helps others.
  45. #35
    Testing Frank's image...:
  46. #36
    May 2019
    Viera, FL
    Another update...moving right along
    Got the firewall, wheels/tires, brakes and steering done. Engine/trans going in this coming weekend
  47. Likes shmelty, Noodles33 liked this post
  48. #37
    Looking Good!
  49. Thanks FLFrank35 thanked for this post
  50. #38
    May 2019
    Viera, FL
    Engine install
    Installed the engine yesterday. It started out straight-forward then we had a little problem with the transmission mount bracket...there is no guidance as to which way to install it. Curve forward, backside, wing-tabs up, down, forward slot, rear slot. The transmission wouldn't really fit either; the rear part of the trans oil pan was hitting the frame/brackets and we couldn't move the engine any farther forward. So we tried flipping the bracket over so it supported the trans spline higher (above the frame bracket) and it worked. I guess it's universal, so you install it whichever way works for your application.
  51. Likes shmelty, DamnYankee liked this post
  52. #39
    Sep 2015
    Bridgewater, MA
    What wheels are those? I like the look!
  53. #40
    May 2019
    Viera, FL
    Thanks, I love them! Rocket Racing Booster Chrome Wheels from Summit. My wife picked them out and they look great. Solid, shiny wheels. And not a bad price...$320 for the 18" (front) and $380 for the 20" (rear).
    https://www.summitracing.com/parts/RPM-R14-886547
    https://www.summitracing.com/parts/RPM-R14-2106555
