Thread: Carb - dominator vs 4150 style
    I'm currently doing some research on dominator vs 4150 style carbs (Assume similar cfms - 1050) to make a decision between them.
    I've never used a dominator before, but what my research is showing is that the 4150 will have a much better throttle, especially w/ street driving, whereas the dominator will make another 15-20hp on the dyno. Does this seem accurate? DOes anybody have any experiences swapping between the two?
    FFR cobra
    RCR Superlite
    RCR 917
    04 Cobra/Z06/Diablo/bunch of other junk
    Senior Member BigLeo69's Avatar
    st. louis, MO
    big carb
    may try to go to the guys at fordmuscle there is some carb guru's there.
    i have a 700 dp 4150 and i like it, mechanical secondaries, choke is manual, probably just keep choke open never had to close it yet
    Mk 3.1 #6945
    Senior Member Big-Foot's Avatar
    Minneapolis, MN
    More options available with the conventional 4150 - not only in manifold choice but in CFM.
    The Dominator was originally created to build a carb that exceeded 1000 CFM and had no Choke provision etc.. The 4150 has evolved further and primarily in the booster venturi area and has exceeded 1000 CFM as well.
    I'd chose a 4150..
    Regards - Randy
    Racecar Fab/Support
    GT40 331 - Weber IDAs, G50 5spd
    69 Camaro SS 4spd
    2007 Toyota Camry Hybrid - 44.2 MPG daily driver
    2002 Avalanche 2500 - Avian Target
    My GT-40 Build Site: http://www.GT-FORTY.com
    Quote Originally Posted by Big-Foot View Post
    I'd chose a 4150..
    Have you ever heard about problems with venturi area when exceeding 1000cfm? I believe the biggest 4150 style is 1050 cfm.......I was reading (and again we all know how reliable internet is, hehe) about how one person felt that over 1000cfm the 4150 has problems, chiefly causing some plugs to run rich, others lean, and that hte solution was either a dominator or to downsize to around 900cfm where the venturi area wouldn't be a problem.
    It's always hard to learn valid info about carbs because there's a lot of good, and bad, stuff out there. Like one thread somebody spent pages arguing why dyno tuning was a complete waste of time, lol.
    FFR cobra
    RCR Superlite
    RCR 917
    Minneapolis, MN
    Sorry Alex - I've not ever heard of that problem..... I think it might have more to do with the scoop or air cleaner than the carb. It might also be the design of the intake manifold.. You will find that some intake designs work better with stagger jetting to fatten up those cylinders that are further away from the center of the plenum.. But those seem to be mostly applicable to old single plane intakes that were used on big block Chevrolet engines.
    Regards - Randy
    Racecar Fab/Support
    69 Camaro SS 4spd
    Forte's Parts Connection
    snakeboost's Avatar
    Framingham Ma on a computer
    With a bigger carb you lose signal that is throttle response at different rpms. It is one reason why given 2 carbs we always go smaller for street cars or any type of road racing. That said we have had more people going larger and larger lately for that extenze feeling!
    Forte's Parts Connection: Your Solution Specialist! Motor & Transmission Packages Starting @ $8200.00 Call To Order 508-875-0016
    Paht time parts guy!!!!!!!
    I was doing a bit of research from what a friend told me and it looks like a Pro-Systems SV1 might be the way to go - 1/2'' shorter than a 4150, same responsivness of the 4150, and dominator style flow. Responses on various forums (e.g., Chevelles) seems to be very positive regarding it.
    Looks like it combines the best of both worlds
    And being a "1 barrel" (lol) means it either idles or GOES! That's my style, heh
    FFR cobra
    RCR Superlite
    RCR 917
    Fort Lauderdale Fl.
    thats alot of carb.............Steven
    FFR Daytona Type 65 Coupe
    67 427 Cobra
    57' Belair
    34 5 window coupe Ford
    2003 Mustang GT
    99' ZX9
    85 Goldwing
