I'll add them tomorrow, thank youI put one average thickness flat washer at each bolt, between the block and motor mount. I can now slide a piece of cardboard between the foot box and all close points on the engine and headers. It is more clearance than I had and put the engine on a perfect level.
The washer location will not compromise the motor mount. If you want to maintain surface contact area, get a fender washer.
Check with Jeff Kleiner. It is one of his revealed tricks.
