Thanks Thanks:  2
Likes Likes:  4
Results 1 to 9 of 9
Thread: Missing anchor/clip for E-brake cable?
    Cobra Doc
    Oct 2017
    Newton, MA
    I’m running the cables for the E-brake with the Wilwood brake upgrade. There is a plastic clip holding the end in the transmission tunnel, but nothing holding the sheath near the caliper. It looks like a retaining clip should be there holding it. Am I missing something?
    Rob
    - Rob
    MkIV Roadster, Complete Kit #9624, Coyote 5.0, TKO600, IRS, Wilwood Brakes, 18" Halibrand Wheels
    Build Thread: https://thefactoryfiveforum.com/show...kIV-Bld-Thread
    There's no clip called out or in my experience necessary. The sheath/cable is stiff and under a bit of tension. When anchored to the Wilwood caliper, it's not going anywhere. Three seasons and 6,000+ miles on my 20th Anniversary Roadster with this setup.
  3. Likes rsw81 liked this post
    Cobra Doc
    Oct 2017
    Newton, MA
    Thanks Paul. Seemed odd and it clearly has a recess on the end of the sheath to put a C-clip of some form. I'll move on!
    - Rob
    I added e-clips on mine. I think they were 1/2 inch. Maybe not needed, but can't hurt. I bought this assortment on Amazon:
    Neiko 50455A E Clip Assortment Set, 300 Piece Kit | Heat Treated Steel Retaining Rings | 1/16" - 7/8-Inch Sizes https://www.amazon.com/dp/B000K7GRDW..._-HCkEb0W451FM
  6. Thanks rsw81 thanked for this post
  7. #5
    Richard Oben's Avatar
    Kansas City MO
    The cables are the same regardless of caliper type. From the factory, the mustangs had the cables installed on the rear end, and would fall out of the caliper before installation in the car. They had clips so the sheath would not come loose when hooking up the front. They were only there for that reason, or they would fall out of the caliper going down the line. They are not needed for the operation of Parking brake. As stated above the cables or sheath never move if the cables are even remotely snug.
    Not that anybody needed to know, but there is also no need for a rush on e clips, LOL. HTH, Richard.
  8. Thanks phileas_fogg thanked for this post
  9. #6
    Richard, no need to confuse people with common sense and facts.
  10. Likes rsw81 liked this post
  11. #7
    Kansas City MO
    That is too Funny, ^^^
  12. #8
    Jax Beach, FL
    Quote Originally Posted by Richard Oben View Post
    But I just told my broker to go long on Amalgamated E-clips stock!
  13. #9
    I hope you weren't planning to retire on that -- two clips per roadster ain't gonna add up to much.
