12
82
Here's what I was referencing with the orange cable. It's from the Coyote instructions. So just add some wire to make it long enough and a connector at the end and plug it into the blue side. Run any wire to a ground or do I need to use that ground wire in the previous pics? Do I not use those wires for anything in that previous pic? (blue cooling fan, green thermo, black ground)
And I guess the coyote instructions doesn't say anything about cutting this red wire, so don't cut it? It says to cut it to make the computer control it, I was assuming that was the Coyote computer.
I appreciate your responses.
25th Anniversary Roadster #12 of 25
Gen 3 Coyote
TKO 600 mid-shift
Car
