2001 MK Roadster missing VIN
Good evening,
This is my first time on the forum and I'm hoping someone can help me with this.
I just purchased a late model MK Roadster and for some inexplicable reason the VIN has been removed from the cockpit above the drivers right knee. Is there anywhere else on the chassis that a serial number or VIN is stamped?
Thank you!
Administrator
Hi Mike, welcome to the forum.
The FRAME ID you refer to exists for MKIII and later kits. Your thread title says 2001. If your kit is from that timeframe the frame ID will be located inside the 2x3 tube viewable on the driver's side behind the left rear tire.
If the local DMV (In Cali it's the CHP) assigned a VIN it could be located anywhere. On my MKIII they did not use the frame ID but instead my VIN is riveted onto the front X-member in between the front tires in the engine compartment.
HTH,
There was no factory vin on that generation car. We used to install a stamped vin on the car we build. There is however a frame production number welded into the 2x4 tube behind the drivers seat . I don't remember of you add 1001 or 1011 to it to get the VIN. You can get that production number and call FFR and they should be able to tell you.
http://i17.photobucket.com/albums/b7...duation/65.jpg
If it's any help at all, my 2004 frame has the number in the cockpit above the driver's LEFT knee.
The 4 digit frame number as stated is welded inside the end of the square tube easily visible with the left rear wheel removed. My VIN as originally assigned by Ohio in 2002 is riveted to the clutch quadrant cover in the engine bay and also added to the frame rail above the knees. As stated, could be almost anywhere. Unfortunately Factory Five won’t be much help, although they would like to. They lost ALL their data in a computer system upgrade in 2005. At least that is what they told me when enquiring about my Mk1.
Mark
Toronto Mike
I just purchased a late model MK Roadster and for some inexplicable reason the VIN has been removed from the cockpit above the drivers right knee. Is there anywhere else on the chassis that a serial number or VIN is stamped? Thank you!
Was the car previously registered in a State or Province, or did you buy an uncompleted kit? If it was already registered it may have an assigned VIN, which is what they do in BC. Mine came from the motor vehicle branch, stamped on an aluminum plate, that needs to be attached to the car. Who knows where the previous owner/builder installed it I would think it would be mounted on the frame somewhere, or perhaps the top of the footbox in the engine compartment, firewall, etc.. The assigned VIN number, may, or may not incorporate the frame number in it.
If it's an uncompleted kit, you would have a frame number, but not a VIN. Here is a picture of the spot on the 2x3 frame on an earlier roadster had the frame number. This is the one behind the passenger compartment, seen best as mentioned, with the left rear tire taken off.
![](https://thefactoryfiveforum.com/attachment.php?attachmentid=81335&d=1519132045)
This is the location of the frame number on the MK3, and 3.1 models.
FFR supplied this with my MK3.1, already with the serial number stamped out, but it is not a VIN number. It's optional as to whether you attach it. Some fellows put them on the top of the foot-box in the engine compartment.
http://www.factoryfiveparts.com/1385...-number-plate/
