Thanks Thanks:  22
Likes Likes:  166
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 121 to 160 of 210
Thread: Jason's 33 HotRod #1142 - Kingwood Texas
  1. #121
    Kingwood Texas
    Quote Originally Posted by tony View Post
    Very pretty color!
    with the springs, is there worry the powder coat will flake off from fatique?
    I don't think so Tony but not sure. The springs that we get from QA1 or just about any others are powder coated too.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  2. #122
    Jun 2018
    North Vancouver, BC, Canada
    Love it. Now to protect it while you put everything around it!
    Gen 1 '33 Hot Rod #1104
  3. #123
    Kingwood Texas
    More Powder
    I was able to make the trip to Lake Charles last Friday to pick up my frame and parts. One thing that I hadn't considered before hand was storage of the powder coated parts and the amount of space that it would take. Wasn't an issue when the parts were all bare metal but I sure don't want to just pile them up now. I ended up clearing out some real estate in the attic of my garage to store some of the parts.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  4. Likes shmelty, Mrallsport32 liked this post
  5. #124
    Kingwood Texas
    Gear Ratio and Posi
    I have a used 8.8 IRS 3.55 ratio center that I'll be rebuilding and changing gear ratio. Looking to hear from the other 5 speed guys here on what ratio your running, but most importantly wondering if your happy with it or do you wish you'd gone with something different. Understanding that this choice is dependent on tire height and cam profile, to fit my combo I'm trying to decide between 3.73 and 3.91.
    Another question for those that have installed new ring and pinion. Did you go with the Ford Performance (which is quite a bit less money) or something like Yukon or Eaton?
    How about pinion yoke/flange, did you stick with the stock part or upgrade. In my case I have the stock automatic style flange. Would you upgrade?
    Also, did you guys use the stock posi or upgrade to a locker or similar?
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  6. #125
    The 3.55 ratio is fine for most driving assuming that you have enough torque and an appropriate size tire. I’m running a 26 1/2 in the rear and can go up to a 29 comfortably. Deeper is quicker...
    Really, the only thing that matters is your final drive. I made the mistake of opting for the deeper overdrive, which puts me at about 1700 RPMs and 70. Little low. Basically a cruising speed I'm below the cam.
    As for the gears, using Ford gears will certainly be better than a Yukon. I don’t know if it’s still the case but the Yukon gear used to be made in Indonesia. Finally, as far as I’m concerned, a posi is mandatory, but the locker would be hell on earth. The cars aren’t heavy enough to unlock a Detroit locker style case. A truetrac would be as aggressive as I would go....
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
  7. #126
    Falmouth, MA
    Stay away from the Detroit locker unless you have had prior experience. They work great on the strip but around town can be quite a hand full. I built a roadster and a t-buket with Detroit lockers and though I was able to control the car without too much trouble, both cars were crashed by the new owners shortly after I sold them. Both cases were making a left hand 90 degree turn. Punched the throtle and rather than turning the car plowed straight across the intersection into objects on the other side of the street. Nobody hurt. I instructed both buyers before the sales, but as we all know, sometimes we forget.
  8. #127
    Kingwood Texas
    Moving at the speed of a drunken sloth lately but I am making a little progress. I have the front suspension set up using QA1’s and Tim’s bump steer kit (really nice looking stuff, glad I did that)
    True to form I decided to do the rear differential the hard way and build it myself. It’s not that hard to do but there are a few special tools required that I had to work around. I ended up building a jig that allowed me to use a readily available case spreader. I also had to buy an extra pinion bearing and machine it for use as a pinion set up bearing. All in all I ‘might’ have saved a few bucks but I just like doing things myself. Good news is that the Ford Performance parts are all very affordable. I ended up using new 3.73 gears and a new Track Lok.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  9. Likes AJT '33, HVACMAN, Ken_B liked this post
  10. #128
    Nice work. You’re on your way to a gorgeous car.
    Titled 2-28-20
    MkI.IV 2643k
  11. #129
    Village Mills, Texas
    Quote Originally Posted by Michael101 View Post
    Good job Michael. Your build looks amazing! We Texas guys like doing things ourselves. The only thing I haven't done by myself , is set the body on. A friend from work came over twice to help with that.
  12. Likes JOP33 liked this post
  13. #130
    Kingwood Texas
    Brake Lines
    Brake lines are done except for the reservoirs. I wish I’d thought to tackle the front lines before installing the front shocks, that was a bit tight.
    I thought I had all of the parts together to finish the install but I ran across a post from Seth this morning showing his cute little braided lines going from the masters to the reservoirs....resulted in yet another Summit order and a bit of a delay...thanks Seth!
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  14. Likes FF33rod, Mrallsport32 liked this post
  15. #131
    Ha! I’m here to spend your money! I will say that the brakes on the car are so good.....
    Titled 2-28-20
    MkI.IV 2643k
  16. Likes Michael101 liked this post
  17. #132
    Jun 2018
    That will only happen another 200 times before the end of your build...
  18. Likes Michael101, HVACMAN liked this post
  19. #133
    Kingwood Texas
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  20. Likes AJT '33, shmelty, Mrallsport32, HVACMAN, JOP33 liked this post
  21. #134
    Feb 2018
    Frisco, TX
    I wish I had a build in the garage to work on, especially during this "social distancing" virus lockdown. Your hot rod is looking very cool - love the frame color! My roadster is at a shop now for paint and bodywork so I have nothing to work on or drive right now to fight the boredom. When I get it back, it will probably be too hot to drive it for awhile. I'm gonna follow this thread, I always thought the roadster with bike fenders would be what I would like to do next if I ever build another. Good luck and enjoy the build!
  22. Thanks Michael101 thanked for this post
  23. #135
    Gatineau, Quebec, canada
    Love your adaptation of the wheel casters, very fancy and useful!!
    Andreas
  24. Likes narly1 liked this post
  25. #136
    Congratulations. Looking great.
  26. #137
    The all black shaved firewall is money! 3m panel bond?
    Titled 2-28-20
    MkI.IV 2643k
  27. #138
    Kingwood Texas
    Quote Originally Posted by sethmark View Post
    I chickened out on the 100% panel bond idea Seth. I ended up counter sinking flat head screws instead and used fewer than normal with a silicone adhesive.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  28. #139
    Find it hard to believe that you chicken on anything. You do great work.
    Titled 2-28-20
    MkI.IV 2643k
  29. Thanks Michael101 thanked for this post
  30. #140
    Kingwood Texas
    Firewall Insulation
    Didn’t feel much like tackling anything major today so I added insulation to the firewall. This may be overkill but the older I get the less I appreciate baking in the south Texas heat. What I have is one layer of Design Engineering Floor and Tunnel Shield plus two layers of Design Engineering Under Carpet Lite. I may wait until installing the trans tunnel to complete the firewall. I used the Under Carpet on my Chevelle and have been really happy with how well it blocks heat from reaching through the floor.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  31. Likes FF33rod, wrp, Mrallsport32 liked this post
  32. #141
    Member Roger Pugh's Avatar
    Mar 2020
    Ephrata, Washington
    Very cool!! I love the red!
    Roger
  33. #142
    Kingwood Texas
    Damnit Beavis!
    I swear ... I’m going to get a custom license plate with ‘DIDNFIT’ on it
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  34. Likes FF33rod, shmelty liked this post
  35. #143
    Welcome to the joy of interdependencies.
    Titled 2-28-20
    MkI.IV 2643k
  36. Likes Michael101 liked this post
  37. #144
    Jun 2018
    Yup. I redid the brake line routing twice in one part of the car ... Remember, this is fun!!! Just think how much easier the next one is going to be knowing what you know now...
  38. Likes Michael101 liked this post
  39. #145
    Yessir. And it’s ALL about attitude and expectations. Expect nothing and never be disappointed.
    Titled 2-28-20
    MkI.IV 2643k
  40. Likes FF33rod liked this post
  41. #146
    Kingwood Texas
    Good one Seth. I’m not really upset about this ‘DIDNFIT’, did it all myself. I must have ordered the distributor before deciding to go with the dual quad setup. So if anyone is in the market for a new (only halfway installed once) MSD 8451 let me know.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  42. #147
    Why not get a $10 phenolic spacer for the EFI?
    Titled 2-28-20
    MkI.IV 2643k
  43. #148
    Kingwood Texas
    I’m about to be exhausted
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  44. Likes FF33rod, Mrallsport32 liked this post
  45. #149
    Kingwood Texas
    DIDNFIT Again!
    This DIDNFIT theme is starting to wear thin
    Looks like my super cool CVF Racing Accessory Drive is a no-go. Really disappointing because I like the look of their setup and they've been very responsive to my needs.
    I started mounting the kit last night only to find that the bracket hits a frame support on the lower pass side. This part of the bracket is where the belt tensioner mounts so it would need at least three inches of clearance to work. I sent the CVF crew a message this morning but I'm not optimistic that they have a different mounting option.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  46. #150
    Jan 2019
    that's an awesome bracket!
  47. #151
    Kingwood Texas
    Exhaust Progress
    I'm almost finished with the easy part of my exhaust setup, which is from the headers to the rear of the drivers compartment. The Gen II has a ton of room to route exhaust in this area compared to what I've seen on the Gen I.
    I started by replacing the socket type connection at the headers with V-Band clamps. The socket isn't a bad option and is typically a bit more flexible for installation. I guess this is just another instance of my obsessing over things that probably don't matter
    I used a Summit 2.5" stainless universal cross-over kit with Summit mufflers to build the first part of the exhaust system. It'll be suspended by one exhaust support located just behind the transmission cross-member. I've ordered DEI wrap for this part of the system and will use their muffler shield material as well. I know that the DEI wrap will trap moisture so just to be safe I coated each of the weld areas with hi-temp exhaust paint, maybe useless but I had it available so why not.
    Haven't really figured out how I'm going to route through the IRS area yet. I have several 45's and a couple of 180's plus a welding machine...and plenty of time to figure it out right?
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  48. Likes sethmark liked this post
  49. #152
    Kingwood Texas
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  50. Likes Mrallsport32, sethmark, JimLev liked this post
  51. #153
    Sep 2019
    Houston, TX
    That is coming along very nice!
  52. #154
    Jun 2018
    Looking great. Hey, just a thought on the front pulley system.
    I put the March Performance Style Track on my 347. Worked fantastic. The belt tensioner was optional and I initially I didn't purchase it. Without it, the tension is set old school with moving the alternator or AC compressor outward to make things tighter. Even though it worked fine I got the bright idea of getting the spring loaded tensioner - found exactly the same as you, there was no darn room for it. So, what about forgetting about the tensioner and just go with manual adjustment? Alternatively, maybe have a look at the March systems
    Cheers, Steve
  53. #155
    Kingwood Texas
    Thanks Steve. My plan was to read through your post this morning to see what you had used, you saved me some reading! Did you buy your accessories separately?
    I thought about using a different style tensioner but hadn’t consider going without. I know that I’ve seen manual tensioners before somewhere. I actually have two main brackets in my possession, the one that came with my kit had a bo-bo so they sent a replacement. I should be able to experiment with the bad one and come up with a working solution.
    Cheers, Steve
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  54. #156
    Jun 2018
    Yes bought the accessories separately, without knowing if they'd fit.
    The key to manual tensioning with either the alternator or the compressor is having a slotted mount so the adjustment can take place. Looking at your picture I don't see any slotted holes which may make it difficult.
    You can see the slotted holes in the upper corners of the mount in this picture....
  55. #157
    Kingwood Texas
    Exhaust Update
    I’ve made it to the rear of the car with the exhaust. I’ll have to make changes with the rear exit though. I should have mocked up the trunk aluminum before finishing the rear part but it was in the garage attic and somehow getting it down seemed to difficult at the time...now that seems dumb
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  56. Likes FF33rod liked this post
  57. #158
    Kingwood Texas
    Accessory Drive
    I started working on my CVF accessory drive today. I had to remove a part of the main bracket where the belt tensioner mounted to make it fit so I’ll need to fabricate a tensioner somehow.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  58. Likes FF33rod liked this post
  59. #159
    Falmouth, MA
    It looks like your exhaust terminates inside the trunk area at this point? Your correct in that I believe you need to fabricate the remaining exhaust once the trunk aluminum panels are installed.
  60. #160
    Kingwood Texas
    Tunnel Mods
    Working on the trans tunnel a bit today. It wold have been fine as it comes from FF but I decided to modify it to get a little more foot room. I’ll pick up about an inch on the driver side and about two on the pass side. Doesn’t seem like much but I think it’s worth the effort. Doing this presents a bit of a challenge around the floor and firewall. With this narrower set up I’ll need to add some support material to which I can secure the tunnel flanged surfaces.
    33 HotRod #1142
    Started 5-9-19
    Kingwood, Texas
  61. Likes FF33rod liked this post
