I have a few questions about what's required to register a roadster in CA. If anyone has a document from the CHP (or the relevant agency) outlining what's required, that would be very helpful. My specific questions are:
- Do I need wipers? I would opt not to install them if they're not legally required.
- Do I need backup lights? I'd probably install them anyway, but I'm on the fence at the moment.
- Do I need DOT-approved safety harness?
I know that many folks have gotten away with not having these things in CA because the inspector didn't look for them, but my luck being what it is, I'm sure my inspector would look for them so I'd rather plan for them now and have them if they're legally required, rather than trying to retrofit them later.
With regard to the harness, I'm guessing the answer is no, because the FFR-supplied harness is not DOT-approved and I've never heard of anyone being turned away because of them. The only DOT-approved harness I'm even aware of is this one from Schroth:
https://www.schrothracing.com/item/p...tion-harnesses
If DOT approval is not a requirement, I'd prefer to use this cam-lock harness from Simpson (with the rotary buckle and 2" shoulder straps for a HANS device for track days):
https://www.simpsonraceproducts.com/...amlock-harness
