Likes Likes:  17
Results 1 to 40 of 52
Thread: Power Steering, Y / N?
    Dec 2019
    I am about to buy a kit and this is another one I have to decide.
    On the one hand the car is light as a feather
    On the other hand a V8 is sitting on really wide tires
    I owned a car with manual steering when I was young and all you had to do was
    to make sure the care was rolling even the tiniest bit and it was ok.
    Bring the car to a stop and you have a workout on your hands
    Not a big deal w/o PS and I tell you for an old car I could feel every pebble under the tires
    On the other hand, one fingered driving aint bad either
    On a scale of 1-10 how hard is manual steering on one of these?
    ....Does F5 have units you can test drive?
    Falmouth, MA
    I have built/owned/driven 7 FFR cars, none with power steering and never really missed it. Currently have a 33 HR and this has the heaviest steering of them all (or is it my advanced age?) but once its rolling no problems at all. I don't believe F5 has test drives anymore (in the early days they toss you the keys and say go have fun. Insurance companies frowned.) Most people who have cars are willing to let you at least sit and ride in their build. Post your location and if anyone is close they'll show you what you need to know.
    Dec 2013
    Sandia Park, NM
    As you mentioned, manual steering is hard when you are stopped. It's a 7 on my scale.
    I added electric power steering after a couple of years with manual. I won't go back. The advantage with power steering is that you can add caster so it tracks straight better. I'm sure others will chime in. The advantage of electric power steering is that it is adjustable on the fly, so you can have manual steering if you want. However, with the added caster, I'm not sure if you would want to!!
    FFR #8305; IRS, 347; T5 Trans; EFI, 3.27 Rear; 17x9" Front; 17x10.5" Rear
    Paint - Ford Magnetic Metallic Gray (J7) with Black Stripes; Painted by "da Bat"
    Complete Kit Delivered 05/15/2014; Titled and Registered 4/14/2017 as a 1965!!
    Seasoned Citizen NAZ's Avatar
    Race cars don't have power steering! I have 6-degrees of caster on my car and manual steering -- no problem for this old man.
  5. Likes GoDadGo liked this post
    Nov 2019
    Charlotte, NC
    I've never driven one without PS and I'm guessing it isn't bad. However, I REALLY like my KRC power steering an it gives just the right amount of resistance as to not feel like a Cadillac. When making my decision I found no one that said they wish they didn't do PS and I wanted my Wife to be able to handle it when she drove it.
    I have built 14 FFR kits. On the ones I built for customers that did not want PS they wished they had listened to me and had it installed once they drove the finished car. Almost every car since the 1980's has had PS and PB. I personally will not own one without unless it is an 818 which is so light it does not need it. Just my 2 cents worth.
    16+ FFR kits and counting!
    I've only built one Factory Five MK4 and it has a manual rack.
    Do I wish the car had Power Steering?
    Nope!
    Note:..The primary use of my car is cruising around with Mrs. Go-Dad & rare trips down the 1/8 or 1/4 mile drag strip.
    Nope!
    Because you don't know any better
  10. Likes GoDadGo, Paul2STL liked this post
  11. #9
    I think this topic has been discussed many times and it's the same every time; strong opinions on both sides. I went with power steering on my car and like it. If properly set up, it doesn't feel light at all, but makes parking effortless. It also improves front end geometry compared with the "standard" manual setup. If you're asking about it, you're probably a good candidate to go power.
  12. #10
    Yup, talked about a lot. You'll get strong opinions on both sides. My standard response: Power steering isn't only about the effort, even though most seem to go there. Including your initial question and most of the responses so far. The big advantage is the improved front end geometry with increased caster. Just plain drives better. I've had both and won't go back.
    https://thefactoryfiveforum.com/show...-Pros-and-cons
    https://thefactoryfiveforum.com/show...Power-steering
    https://thefactoryfiveforum.com/show...anual-Steering
    No, Factory Five doesn't allow test drives. Some have been lucky enough to get a ride from Dave though.
  13. Likes nucjd19 liked this post
  14. #11
    Dec 2012
    Abbeville,SC
    Both here too. PS no question and I’m a muscle bound gear head and always had manual setups. Once I drove one with PS I wondered why I was so stubborn before. Believe me after Building 6 and hardly driving them, anything you do to make the experience more enjoyable will get you on the car more.
    Yeah yeah the shear power and raw race car is fun for a little while.
  15. #12
    Lilburn, GA
    I've driven both. That said, I have PS and power brakes
  16. #13
    Quote Originally Posted by Para View Post
    1:On the one hand the car is light as a feather
    2:I owned a car with manual steering when I was young and all you had to do was
    3:Not a big deal w/o PS and I tell you for an old car I could feel every pebble under the tires
    On the other hand, one fingered driving aint bad either.
    On all three counts you have it exactly right.
    A few further thoughts on each:
    1 - You've got it exactly right.
    2 - You know exactly what to expect, and you ain't as young as you used to be - I started with manual, and it was exactly what I expected + not bad (if you know what to expect). Changed over to EPAS because I wasn't sure I'd want to continue to wrestle with it in advancing years. Also added a 1.5:1 steering quickener for autocross + other enthusiastic driving endeavors and you definitely don't want to try a ratio faster than 15:1 (about as fast as you can get std manual) without some form of power assist.
    3 - You've got it exactly right (and time isn't doing any of us any favors).
  17. #14
    Feb 2017
    Many add it after the fact. Almost none remove it.
  18. #15
    Senior Member frankb's Avatar
    Feb 2014
    Marana, AZ
    As frd2 above stated, I am one of those who added it after the build was finished and driven for a year or so. It was manageable without power steering, especially since I never parallel parked it. But it was a workout when not moving or moving slow! So I added it in (E Power Steering) a year or so ago and am very happy I did. I keep it adjusted to minimum assist level and can only tell it is there when moving slow! Bottom line: If you are unsure, go with electric power steering and you can have it both ways! I'm betting you won't do without it once you have tried it!
  19. #16
    Jun 2020
    Rising Sun , Md.
    I have driven both and I love my power steering!!!
  20. #17
    Woodstock ,Illinois
    After a couple years, went with power steering. Plain old school OEM-type with the pressure spring trimmed to 1 7/16”. Plenty of assist when you need it, and great driving at speed due to the added caster.
  21. #18
    It's no secret that edwardb and I are probably the top two proponents of power steering you'll find here. EVERY car I've built has it and EVERY one who asks me is advised to do it. People seem to think that it's all about steering effort, especially some of the "manly men" who like to do some chest thumping but the reality is that is far from the primary reason. Power steering allows you to run much more positive caster which promotes straight line stability and return to center as well as increasing camber gain while cornering. Plain and simple the car just drives down the road better. For autocross and track use it is pretty much mandatory if you really want to be able to get the most out of the car (some of those same manly men find out that there is no way they can truly hustle a manual rack car). As far as "road feel" this can be tuned to the driver's preference either by the use of a Heidt's variable boost valve or by changes to the pressure relief spring.
    In the end...Just do it!
  22. Likes SSNK4US, Mark Reynolds liked this post
  23. #19
    Senior Member CaptB's Avatar
    Jan 2021
    Memphis, TN
    Power steering.
  24. #20
    This really is a silly debate. There aren't any real down sides to power steering, only upside. As has been stated, the best improvement come in how much better the car drives and handles, ease of steering is second. Had manual steering in the old car, power in this one, was amazed how much the stability of car improved on the highway. Don't think about just do it.
  25. Likes CaptB, NAZ liked this post
  26. #21
    Silly? Perhaps. But is it not silly to run power steering, power brakes, and still shift your own gears when auto trans technology has supplanted the manual transmission? Autos are outperforming manual trans in a variety of racing disciplines -- there's no manual trans that shifts faster than an auto, not even those $30K sequential clutchless transmissions.
    Or maybe it's just one of those personal choice things that makes us feel good. I feel good knowing that I don't have an extra 10lbs of weight on the front end of my race car because I want easier steering at slow speed. However, on my street cars I'd NEVER buy a daily driver without power steering. Even my 1600lb SXS off-road vehicle has power steering and I'm looking at replacing my two 700lb ATVs with ones with power steering. So I get it. But do you need power steering in one of these light cars? That's a personal choice. I know if John Wayne was buying one he'd skip the power steering as a real man doesn't need it.
  27. #22
    Dec 2012
    Houston, Texas
    I installed PS using an early 90’s Mustang pump and a 3 turn LTL rack after driving my car for 18 years with manual steering. It’s the best change I ever made on the car!
    Phil: FFR 3121, Frame #2050, Mk 1.5, built 2002, 1991 donor with Blueprint 302 long block and 1993 Cobra intake, BBK 70mm T/B, no smog, power steering, T-5 and 3.55 rear.
  28. #23
    Nov 2019
    Charlotte, NC
    Correct, stupid debate. I drove a 280Z for 8 years with no PS and i'll never do that again. If you are blasting the car down a drag strip, I get it.
  29. #24
    Nov 2019
    Charlotte, NC
    John Wayne also chose a horse over a bike. :-)
  30. Likes NAZ liked this post
  31. #25
    Jan 2021
    Memphis, TN
    "Race Car" is it really a "Race Car" if you're not actively racing it?
  32. #26
    Quote Originally Posted by CaptB View Post
    Hey Captain,
    If you are talking about "The NAZ Man" his is a race car.
    From the firewall back, his car was 100% fabricated by The NAZ Man.
    Check it out and I'm sure you too will be impressed.
    https://thefactoryfiveforum.com/album.php?albumid=1675
  33. Likes NAZ, CaptB liked this post
  34. #27
    Agree. Just having fun with the debate and my buddy Rich, who I also share many opinions with. Did you notice I'm actually considering trading two perfectly good ATVs in for ones that have Power Steering, and the power steering is the only reason I'm considering them? I truly get it.
  35. #28
    WAIT, so John Wayne's horse didn't have power steering?
  36. Likes Joel Hauser liked this post
  37. #29
    Jun 2020
    Rising Sun , Md.
    Don't NASCAR's have power steering...They are real race cars right?
  38. Likes CaptB, NAZ liked this post
  39. #30
    Senior Member Jim Wehr's Avatar
    Hamilton, VA
    I have it. My car was built for autocrossing, so it really was necessary. However, I have the boost turned way down for the street.
  40. #31
    Correct!
  41. #32
    Senior Member RBachman's Avatar
    Jul 2019
    Yes. And more yes
  42. #33
    South Australia
    When I drove my roadster as a go kart the manual steering felt fine. Once I added the body I didnt like it so much. For me, part of the issue is the confines of the cabin. I find I am only steering with one, to one and a half arms, as my elbow always hits on the door, and I am not a big guy, round, but not big. I guess I could have thrown the drivers door away, but the car gets too much attention already. So power steering was the solution. I only fitted it a couple of weeks ago and I'll never go back.
    Nigel
    Gen1 Coyote / TKO600 / IRS
  43. Likes GoDadGo, CaptB liked this post
  44. #34
    Senior Member JIMOCO's Avatar
    Camp Hill, PA
    Both NASCAR and F1 have power steering but Indy cars do not.
    Mk4 Roadster, Picked up complete kit 8/22/14. Most FFR options except Wilwood brakes and IRS. First start 11/11/14. Go-kart 3/8/15. 347 Stroker, TKO 500, 3-link/3.27 rear. PA street legal 7/29/15.
  45. #35
    Jax Beach, FL
    If you are going to even think about autocross - absolutely.
  46. #36
    Yes for power steering!
  47. #37
    May 2020
    Weight, steering feel, parasitic drag. Not really any question that PS adds weight, adds parasitic drag, and decreases steering feel. May not make it "worse" overall but no question those are real downsides.
    On a separate note, its all a steering effort question in the end. As far as I am aware there is nothing stopping you from dialing in a manual steering alignment to the same specs as a power steering alignment other than steering effort
  48. #38
    Quote Originally Posted by Hoooper View Post
    I do, they bogus
    Weight---the car is 2300#, 15# of steering pump is meaningless, I can take a dump and make 1/2 that
    Parasitic drag---can't get all the power to the ground now, and I'm running Avon track tires
    Steering feel---nothing different at all between this car and my old non-power car, in fact this one is WAY more stable and sure footed
    Go ahead and put 8* of caster in your car and tell me how great the road feel is.
  49. #39
    South Australia
    100% agree with Rich. Just dropped my daughter at school, then went for a spirited drive through some great twisties nearby. (Absolutely perfect driving weather over here right now) First run on this route since fitting EPAS a couple of weeks ago. Parasitic loss? Who cares. This thing is now so much quicker point to point.
    Extra weight? Who cares. It is way quicker. (Took a dump before I left)
    Reduced feel? Slightly, but most feedback was of big tyres trying to wrench the wheel from my grip on tight undulating bends. I don't miss that.
    The car feels safer as it can be recovered quickly and is now rock solid. Oh yeah, did I mention that point to point is way quicker.
    Over and out
  50. Likes CaptB liked this post
  51. #40
    CobraboyDR's Avatar
    Jun 2017
    Need some info here:
    Why and how does PS allow more caster in a FFR?
