01-25-2021, 11:47 PM
#281
01-26-2021, 08:01 PM
#282
I like the cup holders, I have similar. I think you will find that they will blow out, I don't think the "O" rings will hold them in. If they do, here is the fix I did after mine blew out and went flying... Click Here.
Post Thanks / Like - 1 Thanks, 2 Likes
Fman thanked for this post
01-26-2021, 11:18 PM
#283
Originally Posted by
BadAsp427
Click Here.
Carl, great idea... thanks for sharing. Definitely do not want a cup holder flying out! Looks like a couple clamps are going to be in my future.
01-27-2021, 11:37 PM
#284
01-28-2021, 12:36 PM
#285
Fman. I've read not to use the set screws and, as a result, I have never used them. I just tighten by hand and give them a light whack with a rubber mallet. After a few drives, tap them again with the mallet. If any move, whack them a little more. Not scientific, but seems to work and you will shortly get a feel for how much you need to keep them tight. They should tighten opposite the direction of rotation of the car moving forward. If I remember correctly, tighten in the direction of the rear of the car.
The O-rings make the assembly process much easier. I used anti-seize ln the threads of mine. However, I will be switching to the Spinner Eaze next time I have to take my wheels off.
01-28-2021, 04:45 PM
#286
25th Anniversary #9772
looking good Travis!! what are you doing for a reverse light?
yes, with all this rain and wind, should be building a boat
01-28-2021, 08:35 PM
#287
TMartinLVNV
Terry, thanks for the clarification on the set screw.
Here is the way I have them mounted, basically forward to take off, towards rear of the car to tighten. Hopefully this is correct I will give them a light tap and call it good. I have loosened them once just to make sure they release and they broke away pretty easily. I just used a small spread of the spinner eaze on the threads, directions say it does not take much. Stuff is kind of goopy and messy.
01-28-2021, 08:37 PM
#288
toadster
Hi Todd, I picked up these lights. I will mount one right under the bottom center of the car. These are not DOT approved but I read a post where someone used them in CA and passed light inspection. Not sure if I will keep them after inspection is done.
01-28-2021, 08:41 PM
#289
Cobra Herb - door panel
I also opened up my door panel package from Cobra Herb, I sent him some pieces of my leather hyde I am using on the car (dash, center console) to match up to interior. He did a really nice job on these and they will be a perfect match.
These are his "standard" panel
https://cobra-herb.tripod.com/
01-28-2021, 10:13 PM
#290
"Here is the way I have them mounted, basically forward to take off, towards rear of the car to tighten. Hopefully this is correct "
You got it!
Post Thanks / Like - 1 Thanks, 1 Likes
Fman liked this post
02-01-2021, 10:21 AM
#291
It helps to understand why the spinners are reverse threaded on the right side of the car. The spinning motion of the wheels will tend to tighten the left side as they turn forward, but on the right side it would tend to loosen them because the forward motion acts in the same direct as loosening a right hand thread, thus a left hand thread is used. My first car was British and had wire wheels with knock off hubs and my dad was certain that I would loose a wheel at some point, so he hammered this point home.
As far as treatment of the spinners go, I use the o-ring, the set screw, no lube and a dead blow hammer to tighten. I figure as long as the threads are kept clean of corrosion they will do fine. The set screw has not done any real damage to the threads and in 3500 miles I’ve never had a spinner come lose or refuse to come off when I needed it too.
BTW, those door panels are one of the best purchases I made, very handy!
Bradley
02-01-2021, 09:28 PM
#292
GTBradley
Totally makes sense, although it is a little confusing when you first get everything set up. Good to know about the set screw, I might use that and just snug it up.
I am still really impressed with Cobra Herb and how good of a job he did on the panels. And I can see that pouch is going to come in handy for small items. I feel like I have some basic necessity items covered with this car, I can hold a Venti Coffee in my cup holder, turn on heated seats and storage pockets in my door panels Life is good!
02-02-2021, 09:30 AM
#293
GTBradley
Fman
Okay, fine, adding that to the build plan. Good thing this is a hobby and not a project with a budget ...
Meandering, leisurely build thread is
here
02-02-2021, 11:47 PM
#294
John Ibele
As soon as you press the order button for a FFR Cobra the word budget is never thought about or discussed again! just remember you cant take it with you....
And those door panels are well worth the $160 Cobra Herb charges.
02-03-2021, 07:07 AM
#295
Fman
if you're lucky, you might catch one of Herb's flash sales. he'll give a discount for the first 10-20 people who respond to his post. that's how I got mine.
02-03-2021, 10:25 PM
#296
John Ibele
X2 on the panels. I looked at his website, and may consider the wider versions. Very similar in price, We'll see once I get closer to that part of my build.
And, yeah, to quote Sir Paul (and others), "Budget...what budget?!?"
Coupe complete kit delivered: 4/22/24.
Build Thread. Coyote. T-56. IRS w/3.55. Wilwoods. PS. HVAC. Side windows.
MK4 Complete kit.
Build Thread Index. Delivered: 10/15/2020. Legal: 7/25/23. Coyote Gen3. TKO600 (0.64 OD). IRS w/3.55. PS. Wilwoods. Sway bars. This build is dedicated to my son, Benjamin.
Build Thread.
02-06-2021, 03:17 PM
#297
02-06-2021, 07:10 PM
#298
You Do Darn Good Work Fman!
02-06-2021, 09:34 PM
#299
GoDadGo
Thank you, just copying a lot of mods from yourself and other builders on this forum. It is kind of odd, I am reaching a point where my car is about at the point where I can't do much more on it until the body goes back on. Even after that milestone there are only a few small items left to take care of and I could be on the road!
I took my wife out for a go-kart run today, weather was beautiful here...64 and sunny. it was awesome to look over and see her in the passenger seat! she really enjoyed it...cant wait to take it out for a nice long drive someday
02-07-2021, 12:09 PM
#300
Thanks for the recommend on the extinguisher, Travis. Good to see what an expert in the field is using to protect himself, and his roadster! Made a note of it.
MK4 Complete kit.
Build Thread.
02-07-2021, 11:25 PM
#301
Fman
After go-karting a few times I have been struggling with the pedal box and having the brake and gas pedal interfering with each other when pressing on them. I have size 13 feet and this pedal box does not like big feet, so I ended up moving the brake and clutch pad out even further. I also adjusted the Russ Thomspon gas pedal. This setup seems to be working better, I will probably also buy some type of driving shoes to narrow up my feet as much as possible.
I bought some Puma Drift Cats for driving. I'm pretty happy with them.
02-08-2021, 09:49 AM
#302
You need to consider a dead pedal. Ask me how I know.
02-08-2021, 09:55 AM
#303
460.465USMC
I am easily replaceable more concerned about the roadster
I have noticed a lot of guys will also keep a 5lb extinguisher in the trunk. The 1lb extinguishers are good for a quick knockdown to prevent a larger fire. Hopefully nobody ever has to use one for there car, that would definitely be a bad day.
02-08-2021, 09:59 AM
#304
Railroad
Any pics on what you are using? I have considered adding it.
02-08-2021, 12:12 PM
#305
Here's one idea. I used some aluminum L-bracket material from HD or Ace, cut some ears on it and bent them to fit the frame on the outside of the footbox:
I cut a blank out of 0.090" aluminum plate:
I spent some quality time with the drill and the countersink bit and ended up with this:
A quick hit with a sanding block and some 320 grit gave it a nice consistent satin finish. It provides a good foot rest with my foot below the stomp switch for the hi-beams, and there's plenty of room to lift my foot up and hit the switch:
One more note: I decided after looking at the dead pedal in place for a bit that it looked wrong with the curvy shape on the right side. Great, its shaped to the foot but you don't need all that support on a dead pedal. I'd put it in my dune buggy if I ever wanted to own a dune buggy. Which I don't.
I trimmed it to a straight rectangle shape with just the two columns of lightening holes and it looks much better now. More functional and race ready. Still all the support for the foot right where you need it. I can pull measurements off and take a photo of the refined shape tonight if you like.
-- John
PS Size 11 shoes.
here
02-08-2021, 06:47 PM
#306
John Ibele
is that a foot button for high/low beams? looks awesome!
02-08-2021, 08:45 PM
#307
John Ibele
-- John
PS Size 11 shoes.
Nice work! that looks awesome. I think I am going to just go with a basic 2" (w) 5 1/2" (l) piece similar to what breeze sells and keep it simple and easy. Planning on using Rivnuts to make it removable.
02-08-2021, 08:49 PM
#308
I was at the big orange today and found a 2" quick cap, if you are in go-kart this comes in real handy for a fuel cap. It is easy to remove/install and does a good job sealing off all the fumes. Prior, I was using some gorilla tape and every time I went to add some fuel it was a PIA.
I think at HD they are $3 you can also find one on Amazon
https://www.amazon.com/Fernco-QC-102...1&rps=1&sr=8-5
02-08-2021, 10:58 PM
#309
Fman
I was at the big orange today and found a 2" quick cap, if you are in go-kart this comes in real handy for the a fuel cap. It is easy to remove/install and does a good job sealing off all the fumes. Prior, I was using some gorilla tape and every time I went to add some fuel it was a PIA.
Great idea, Travis! Noted. I especially like tips that are very functional AND cheap!
MK4 Complete kit.
Build Thread.
02-08-2021, 11:03 PM
#310
John Ibele
A quick hit with a sanding block and some 320 grit gave it a nice consistent satin finish. It provides a good foot rest with my foot below the stomp switch for the hi-beams, and there's plenty of room to lift my foot up and hit the switch:...
-- John
PS Size 11 shoes.
Hi John. If it's not too much trouble I would gladly accept a photo with measurements, etc. Can you PM it to me?
MK4 Complete kit.
Build Thread.
02-08-2021, 11:52 PM
#311
Railroad
OK, I'm adding this to my "to do" list. Thanks for sharing!
MKIV Complete Kit #9822 l BluePrint 347 EFI l TKO600 l Power Steering l Heater/Defrost l
02-09-2021, 09:47 PM
#312
02-16-2021, 10:38 PM
#313
Post Thanks / Like - 2 Thanks, 2 Likes
02-17-2021, 03:45 PM
#314
Blocked for Primer
Got a nice update today from Ken Pike, my car is being blocked for final primer!
02-18-2021, 11:10 PM
#315
02-19-2021, 02:54 PM
#316
02-20-2021, 10:17 PM
#317
Received my Speed hut temp gauge, they converted it from Celsius to Fahrenheit. I was not a fan of the Celsius display, felt like I was doing math conversions in my head every time I looked at the gauge...and I am not good at math! It is a $14 charge plus shipping and about a two week turn around time to have the gauge converted over.
02-24-2021, 12:21 AM
#318
Post Thanks / Like - 1 Thanks, 4 Likes
02-27-2021, 08:03 PM
#319
Mustang E-brake spring mod
There have been a few people that have had issues with the Mustang rear brake calipers not disengaging when the e-brake is released. I figured I would add the "spring brake" modification to avoid this happening. A shout out to Alexmak (aka fastest quarantine builder on the east coast) for giving me the links to pick up the necessary springs. Thanks again Alex!
Picked them up from Amazon:
You run the larger 9705 inside the 9712 for a double spring setup.
Springs installed on the rear caliper
Post Thanks / Like - 2 Thanks, 3 Likes
03-03-2021, 04:28 PM
#320
Let the striping begin...
Ken is making some more progress, stripes are starting to come to life!
