Hi Guys,
I'm working on my dash wiring. I added a hole for a fan over ride switch when I cut the dash. For some reason I thought that was part of the wiring system. Evidently not. SO, now that I have the switch in the dash, has anyone ever wired up one of the FFR switches to be a fan override, so it's just on all the time vs engine sensor controlled? I'd also like to use one of the indicator lights to show the switch is on. Has this been done before?
Concerning the heater control cable. Where is the best place to put the hole in the firewall for the cable to pass thru? It seems the best place for routing of the cable would be directly in front of the heater controls in the dash, but I just want to make sure there's nothing else that will cause me issues if I drill it there.
