Thanks Thanks:  15
Likes Likes:  34
Page 5 of 5 FirstFirst ... 345
Results 161 to 177 of 177
Thread: fletch's question thread
  1. #161
    Placitas, NM
    Quote Originally Posted by fletch View Post
    Went to my local dealer who said they don’t sell it anymore. Gave me specs of GL-5 80w-90. My local guy said to buy that in synthetic and include 1 qt of GM Synchromesh in the fill. I suppose by posting this stuff I’m encouraging the back and forth, but really would welcome insights.
    Gator, does the “NS” at the end of the Redline PN mean not synthetic? Or something else?
    Thanks for the input.
    How are you making out on the transaxle?
    Info.....
    https://www.redlineoil.com/75w90-ns-gl-5-gear-oil
  2. #162
    Syracuse, NY
    It means "no slip" This is for gear boxes that do not have clutch type LSD's.
    I ran Red Line 75W90NS GL-5 Gear Oil in my 5MT and it was great, shifted very nice. I have 6 qts left I can sell you for a good price, new never opened. if your interested
    MK3.1 Roadster completed 2011
  3. #163
    Senior Member fletch's Avatar
    Dec 2018
    Just outside ABQ, NM
    Thanks for the explanation Hobby. I’m interested in the Redline. PM me with your price, please. My zip code is 87124.
    StiPWRD, a replacement transmission is definitely a possibility. At the moment, I’m waiting for a replacement gear set from Rob T to see if I can drop it in to my case. If that works, then I think we’ll be done. If not, I’ll be looking for other solutions.
    Jim, no progress on the trans yet. Lots of clean up of electrical wiring, though. Pics soon.
  4. #164
    Dec 2018
    5MT question
    I swapped in Rob T's complete main shaft assembly along with his driven gear shaft, but retained the old pinion shaft because his pinion gear was broken. The differential is also from our old gear set.
    We did not move the differential side retainers during disassembly - these are the adjusters in the case halves. I presume since the same differential is being used, we don't need to measure or adjust backlash on the diff. Anybody know if this is true?
    I am a bit concerned that there may be another backlash adjustment I'm missing. In the manual, the only adjustment for the pinion shaft is the thrust bearing preload. I believe this is obviated by the use of the double-splined center differential lockout adapter from FFR. Though, honestly I'm not sure. I'd appreciate any help you all can offer.
  5. #165
    Syracuse, NY
    You should not have to adjust the pinion backlash as it has not changed. There is another backlash adjustment on the pinion shaft, the stack of thin shims between 5th gear and the case bearing but it should not need changes. I did not need to change mine when I swapped some gears in my 5MT.
  6. #166
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    You have put enough effort into this - I'd suggest you consider checking the pinion backlash anyway. If for nothing more than (a) bragging rights to yourself that you did it (b) not relying on whether it was all that correct before you came along (3) it will not seem like all that much of a hassle once it is half done and for that matter all done (4) now you are a pro (or closer).
    I rather dreaded it thinking it was above my pay grade, then did it (and I had about 3 or 4 adjustment cycles - open the case, adjust it, close the case and check it) and really felt like a hot shot when I was done. Transmissions like toasters, are complicated and MUST be serviced by professionals, not hackers. But if you can follow instructions and do careful work maybe you can become a pro instead of a hacker.
    In my case my pinion and crown were replaced by me (so had to check it) due to a rather large bit of other gear tooth that had gotten between the two before I inherited the trans.
  7. Likes AZPete, Santiago liked this post
  8. #167
    Dec 2018
    I hear you, Art. And I'm thinking I may follow your suggestion and just do it myself. The problem for me is that I'm not sure which set of instructions to follow for setting the driven/pinion shaft in its proper fore/aft position. Hindsight did me a huge favor in showing how to set the left/right position and preload on the differential here https://thefactoryfiveforum.com/show...ions-with-pics.
    But I've looked through the FSM for the 06 donor and can't find anything more about the driven/pinion shaft aside from the "thrust bearing preload" I mention in a post above. Am I missing something there, or is that shaft just fine where it is and the diff procedure handles all the backlash adjustment?
  9. #168
    aquillen's Avatar
    NW Indiana
    I've got an 06 manual and will look it over to see if there is a gem in there.
  10. #169
    Dec 2018
    OK. I re-read the whole FSM portion on the transmission today and see that I can perform the backlash setting on the differential per Hindsight's guidance, including measuring with the dial gauge. After that, I can perform the hypoid gear tooth contact test to confirm or correct the pinion shaft shim thickness. Would appreciate the double check. Would also like to hear what others have used as a gear contact witness in place of the FSM's "red lead."
  11. #170
    aquillen's Avatar
    NW Indiana
    Glad you found it, knew it had to be in there. I used Permatex "Prussian Blue" in tube paste. Item# 80038. Napa or Autozone, either or both have it, don't recall which.
  12. Thanks fletch thanked for this post
  13. #171
    Dec 2018
    For 818 Coupe Builders
    Can we install this aluminum panel now, or do we need to wait until the hardtop is in place so we can snug it up properly?
    We would like to put it in and tidy things up a bit wiring-wise.
  14. #172
    Chicago, IL
    So that's where that thing goes...
    Sorry, just a little R-to-C builder humor. They sent it with the kit, but I didn't use that panel (until I cut it up and found new life for it).
    Executive Director
    The Community Garage
  15. #173
    Thinker of thoughts FFRWRX's Avatar
    Bolton, Ontario, Canada
    Good question. I’d like to know that too. Not sure about the order of hardtop, dash, that piece, windshield.
  16. #174
    Leesburg, VA
    I'm building the S but the wind shield cowl is very similar underneath to the coupe. I'd suggest waiting until you have the roof in place. You may either have to trim that sheet later or end up with a gap.
  17. #175
    Senior Member Dave 53's Avatar
    Jun 2020
    Danville CA
    I would wait until the windshield trim is in. If you're anxious, just do a rivet on each end, but wait to drill the rest of the rivet holes until you have the windshield trim installed.
  18. #176
    Dec 2018
    Thanks for the several responses. Very helpful.
    I’ll wait to secure it with two rivets (probably Clecos, tbh) until after we spend some time at our local track ironing some things out. We won’t tie it down completely until we get the hardtop aligned properly.
  19. #177
    I spit that aluminum piece in the middle and trimmed it to go around my wiper motor.
  20. Thanks fletch thanked for this post
