By request! Thanks (or rotten tomatoes) go to ILPBFoot for the suggestion.
David,
Thanks much. You responsiveness is much appreciated.
Wow! We're famous! Well, sort of. Maybe not. Nevertheless, we have a place where we can talk about Chicago-style hot dogs.
I’m here too!
Looking forward to getting together. Need to get the weather to cooperate
I'm in!
Mk4, IRS, (Forte: 427 with EFI, T-56 MAG, hydraulic clutch, mechanical linkage, reverse lockout control module) (Breeze: Front and Rear Double adjustable QA1's, Cockpit cubby, LED Lights, Fan Shroud, Fan Lower Support, Oil Cooler Coil, power steering hose kit) (Russ: Drop Trunk, Turn Signal)
I have strong opinions about folks behind the cheddar curtain ... especially ones that wear green and yellow...
Thanks for setting this up Steve and looking forward to our future events!
MKIV #7275 Acquired June 2019 (2010 partial build), Gen 2 Coyote by Forte w/TK600- PRO 5.0 - McLeod RST twin Clutch-QT Bell, old style IRS, 8.8 3.55 Rear, Gas'n Headers/Pipes, Power Steering, Hydroboost by Forte, Breeze Roll Bar, Heated Seats, 17" halibrand w/ Nitto G2, Maradyne Fan Controller, Paul Proe Vent Kit, Russ Thompson Signal w/ FTP- Received June 2019/First Start April 2020/Go Cart May 2020/Legal September 2020/PAINT BY SPOTLIGHT CUSTOMS JAN 2021
I’m in, that is if you guys will allow me ? I’m a truck guy # 16.
Rob
FFR 35 p/u # 0016 Dart 347 TKO 600
Nothing wrong with the green and gold, just look at what Jim McMahon jus staid about where quarterbacks go to die!
Anyone going to the London Cobra Show in Ohio, on June 24, 25 AND 26, 2021?
https://londoncobrashow.com/
I'm going. Looks like Sten, Al and Craig are registered too. Still deciding on trailer or drive.
80+ degrees on Tuesday! Who wants to play hookie from work and go on a cruise Tuesday afternoon?
I can not I’m recovering from a broken shoulder 5 weeks ago from a skiing accident. I’m going to putz my way to a car show in Gilbert’s this Sunday which is about 5 miles from my house. I need to get out of the house I’m going nuts. Rob
Cobra London Show:
I'd like to go (first timer). If you have been there before, what hotel would you recommend? And, is it typical to stay over on the 26th?
This will be my first attendance in London as well. We (my wife and I) are staying at the Marriott that has a block of rooms set aside for the show. You can book it directly from the LCS web site! I think most people drive to OH on Thursday and leave for home on Sunday morning.
Last item: last year we were supposed to meet up with a bunch of people at the I-294 oasis in Hinsdale, then drive to the state line where we'd meet more, and so on. I believe Craig (abdw-wcw) set it up last year - maybe he's doing that again?
I just made reservations for the Cobra show. I'll be staying at the Marriott too.
I plan on leaving Thursday morning-ish 24th and returning Sunday 27th.
