Yes it will GT. Here is another option.
https://www.longacreracing.com/produ...y---NO-ADAPTER
At this price you can buy two. Here is my mount. A piece of shelving so I didn't have to paint it.
Align tool by craig stuard, on Flickr
I used the bungee because it was quick and, at the time I only had one gauge. Later I made up a J bolt and wing nut attachment that hooked to one of the spokes in the wheel. Covered the end w/ some rubber hose so it would not scratch the wheel. The gauge comes w/ a coarse threaded hole so I loctited the short stud in place. A couple of fender washers, nylon washers, and a nylock let me tighten it just right so it doesn't sag but will twist to center the end bubble.
20180606_134740 by craig stuard, on Flickr
The two aluminum pieces are velcroed in place and make it easier to eyeball the 20 degree steering turn needed whne measuring caster.
