Has anyone done a Porsche Boxster engine in an 818?
There's a lot of build threads to wade through, a bit overwhelming for me, and the search system isn't really coming up with what I'm looking for. I saw several threads mentioning Subaru, Porsche, and some Audi engines can go into the 818, but is there a list?
I'm currently looking at the following cars as donors:
Most Exciting
2016-now Porsche Boxster 982 MA2.2 - Seems perfect for turbo. 300HP, smallest, lightest weight
I found some MA2.2s wrecked for reasonable prices compared to running WRX donors these days. It seems to be the least desirable engine for Porsche as far as I can tell, but it seems relatively perfect for this application. The engine and especially the trans look quite small.
I'm not an expert on any of this by any means, but I assume the fabrication at best would be engine mounts that position the transmission axle holes at a decent position, a transmission mount that does the same, potentially custom axles, and all kinds of wiring harness joys, although, this may be easier than I think since everything is in relatively the same general position as in the Porsche.
In any case, anyone done this yet? Seems like going electric is easier.
I love the idea for the motor, but remember there is a ton of other Subaru stuff you will to finish the car. Suspension, steering, etc. I think coat wise it would be a wash at best.
Personally I would love the challenge of getting the Porsche engine / trans to work but it is going to be a lot more work than you imagine. Unless you get the entire car, cobbling together an ECU and wiring harness that works is going to be a huge task. And then there is the frame modifications that will be needed to fit the Porsche engine. The 818 engine bay is lot long enough for the Porsche 6 cylinder. I put in a Subaru 6 cylinder, which is shorter than the Porsche, and still needed to modify the frame for it to fit.
Other engines I know that have been used include:
VW VR6
Honda K24
Mazda Rotary
Ford EcoBoost 4 cylinder
Subaru H6 EZ30 & EZ36
All manor of Subaru H4 engines
Electric drivetrains
Oh, I'm sure none of it is actually easy, but what I meant was the transmission is already setup for linkage to the rear, the wiring harness for a Porsche goes from back to front, the transmission doesn't have to be converted from 4wd front engine to 2wd mid engine, etc.
