Thanks Thanks:  2
Thread: F5 Electronic Gauges
    Senior Member svassh's Avatar
    Apr 2021
    Highland Village, TX
    Hi
    The MK2 that I purchased seems to have newer MK4 style electric gauges. They look identical to this set except my GPS speedometer has small jewels inside the gauge for turn signal and bright indicators. Based on the video there appears to be a way to activate other features on the LCD of the speedo for trip, 0-60 etc. For the life of me I have not been able to figure out how to trigger those features.
    https://www.factoryfiveparts.com/160...s-speedometer/
    What am I missing? I have located a button under the dash but pressing it or holding it has no impact on the display. Not certain what it is hooked up to maybe nothing
    Scott
    MK2 Roadster - 347 - Boss 302 Crate 4x2 Weber 44 IDFs
    Golden Valley, MN
    The one you linked to uses a remote switch to control the alternate functions. Check to see if the gauge you have has that option. Perhaps the button you found is hooked up to program a different gauge or unplugged all together?
    https://www.speedhut.com/ecommerce/p...ramming-Button
    FFR MK4 #8849. 2015 Coyote, 2015 IRS.
  3. Thanks svassh thanked for this post
    Apr 2021
    Quote Originally Posted by Kerns BBO View Post
    Thanks, that looks like the button I have under the dash. Guess its time to get on my back turn my body 45 degrees and get my head under the dash.
    Dublin, OH
    feel the back of the speedo to see if the push button cable is attached. it might be attached to the clock as it also helps set your clock. or you could do what I did and buy an extra cable/button to permanently have one for the speedo and one for the clock. The clock notoriously runs fast and has to be reset every so often. Coincidentally, the speedo has a clock function as well that is always correct since it's GPS-fed.
  6. Thanks svassh thanked for this post
  7. #5
    Apr 2021
    Thanks, did not know it was for the clock also. My clock is not powered so haven't bothered with that one yet. I traced the wire from the button and sure enough RCA jack on the end attached to nothing. Plugged it into the speedo and it works now.
    Now for the next shocking find the Speedo apparently tracks highest speed and mine shows 136 MPH!
  8. #6
    Senior Member JB in NOVA's Avatar
    Apr 2020
    Virginia
    Quote Originally Posted by svassh View Post
    That's impressive, and actually pretty cool that it's memorialized.
    MKIV Complete Kit #9822 l BluePrint 347 EFI l TKO600 l Power Steering l Heater/Defrost l Build Thread
  9. #7
    Dublin, OH
    Quote Originally Posted by JB in NOVA View Post
    Now you have a goal to beat!
  10. #8
    Heart of Dixie, Alabama
    ,,,, and that was while on a trailer!!!
  11. Likes WIS89 liked this post
  12. #9
    Apr 2021
    LOL, I was thinking dyno but I doubt a GPS Speedo works on a dyno.
