Before I switch to a different e-brake system or wheels, I'm going to see if I can modify the parking brake bracket to bring the calipers a little closer to the rotor. From what I see the clearance is only off by one or two millimeters, so if I can bring the calipers in that would allow me to keep my current set-up.
