Frame notch for driveline clearance. At bottom of hoop in rear of cab, cut ¾” out of the horizontal tube under the driveshaft. Smoothed transition with fiberglass and epoxy. Reinforced cut section by adding heavy SS strap under the tube section I cut away.
IMG_4365 - Copy.JPGIMG_4379 - Copy.JPGIMG_4380 - Copy.JPGIMG_4383 - Copy.JPG
