Thanks Thanks:  7
Likes Likes:  19
Page 5 of 5 FirstFirst ... 345
Results 161 to 176 of 176
Thread: 289 USRRC - vspeeds - #9180 Build Thread
  1. #161
    Elk Grove, NorCal
    Heres an update. Im still in the process of getting the car registered. I had my CHP appointment and they assigned my VIN. Then i immediately went to DMV and they issued me my SB100 sequence number and a temporary operating permit. Now i have to wait for the physical certificate in the mail from DMV. When i receive that certificate i could go to the CARB referee for an inspection and that should finalize my CA DMV registration process.
    I have about 1300 miles on it now. Unfortunatelly last week while driving on the freeway, my engine just died. I had to get the car towed home. Turns out my MSD ignition box went out and i have to replace/repair it.
    Kit purchased: July 25, 2017
  2. #162
    Elk Grove, NorCal
    Update
    My apologies to my relatives that have been bugging me asking for an update. Well here it is. Back in August 17, 2019, I had a bad coil and I replaced it. Everything ran fine until later that day when a backfire occurred and the engine stopped running. I couldn't start the car. Had it towed home, again. Turns out the camshaft gear stripped! AND IT WAS 2 DAYS PRIOR TO MY APPOINTMENT AT THE CALIFORNIA BAR! So I had to pull the engine , again, and sent it to TEM Machine Shop in Napa, CA. Rich at TEM's tore the engine apart and for the most part there was minimal damage to the engine and components. The camshaft which was a proprietary cam from Roush did not have an over the counter replacement with the same specs. Since I liked the cam when it was running, we decided to have Schneider Racing Cams out of San Diego duplicate a billet cam for me. So I got the engine back and installed it back in the car on January 17, 2020. Everything seems fine. So I'm back into the CA registration process. I have an appointment to the CA BAR on January 22, 2020. Hopefully everything passes and I'm planning on going to DMV immediately after the inspection to finally get this car registered. I'm so close and I can't wait!
  3. #163
    Mark Eaton's Avatar
    Medford, Oregon
    Holy crap Eddie! You've got to be kidding me! First your throw out bearing thing and now this?! All I can say is "Hang in there Brother" !!
    Mark
  4. #164
    Elk Grove, NorCal
    Mark
    Mark
    The hydraulic release bearing failure was 100% my mistake. I let the bleed line rub up against the rotating clutch. This camshaft from Roush is a mystery. Roush did admit back in the era my engine was built (2009) there was a bad batch of Twisted Wedge cams. However, since I installed the engine 9 years after it was built, it was no longer under warranty. I had the engine repaired locally and its all good now.
  5. #165
    Elk Grove, NorCal
    CA SB100 registration completed
    FINALLY GOT MY LICENSE PLATES AND THE CAR IS LEGAL TO DRIVE! Went to DMV on January 23, 2020 and now its fully registered under CA SB100, smog exemption!
  6. #166
    Sep 2015
    Beachside
    congratulations Eddie!
    FFR #8833 289 FIA 3-link
  7. #167
    Elk Grove, NorCal
    I've been practicing social distancing by commuting to work and taking the backroads. I have over 3500 miles on it so far. Besides having to still fine tune the Fitech EFI (after start rough idle for 10 seconds), everything. is running great. I love driving this car! I added a luggage rack and plan to use it this summer when this whole Covid-19 craziness dies down. I also added a quick release removable steering wheel. If anybody wants to add a quick release removable steering wheel and are using the Russ Thompson turn signal, here is a great thread:
    https://thefactoryfiveforum.com/show...on-turn-signal
  8. Likes cnutting liked this post
  9. #168
    Mark Eaton's Avatar
    Medford, Oregon
    Eddie, good job on the social distancing and it is awesome that you are using your 289 for your long commute! I too am loving driving my MK4. I've got 500 miles on it so far.
  10. #169
    Jun 2019
    How did the build go. I am new to this and appreciated your words. Considering the 289 also. Thanks Rich
  11. #170
    Elk Grove, NorCal
    Quote Originally Posted by Yolo View Post
    Rich
    The build was fun. I sent you a private message.
  12. #171
    Senior Member OttawaFFRer's Avatar
    Ottawa, Canada
    Quote Originally Posted by CobraboyDR View Post
    Here is a drool-worthy 289FIA from Unique:
    I like wires, but I also like these FIA wheels.
    I'd delete the roll bar and rear bumper, opting for just overrriders, but I suspect registration required it. IMO, it's mounted wat too far off the body.
    The color? Cosmic, and the tan interior is excellent!
    This is the first car I've noticed the drivers side dash is cut higher than the passenger. I wonder if it's unique to unique cars.
    Currently working on the dash so pouring through the build threads yet again.
    10 years after my roadster build....
    289 FIA (pickup 28/08/20 if covid permits)
    currently building a 289 and accumulating parts needed to finish a Canadian Kit.
  13. #172
    Elk Grove, NorCal
    Thats a sweet car.
  14. #173
    Elk Grove, NorCal
    Here is a YouTube video that Travis D made of my car:
    https://youtu.be/UYypZiWWUJQ
  15. #174
    Sep 2020
    Excellent build thread, with a lot of "nitty gritty detail" things to learn. Thank you for all the updates and your hard work!!!
  16. Thanks Vspeeds thanked for this post
  17. #175
    Member jolsen42's Avatar
    Mooresville, NC
    I see that you didn't finish the grill, Any reason? or do you just like the look without?
    John O
    FFR 1293K - First Factory Five slabside. Replica of CSX 2367. 289 Hi-Po, original Cobra dual quads manifold with original Carter 3258s and 3259s carbs, Dayton wire wheels, Tremec 5-speed, 355 trac-loc rear, original Amco Cobra luggage rack.
  18. #176
    Elk Grove, NorCal
    Quote Originally Posted by jolsen42 View Post
    John O
    I drive the car a lot and the grill would be a pain to clean. I can barely keep the brake dust off the wheels.
