20
40
edwardb- Thanks for the feedback and recommendations. I'll have to look into the KRC PS setup vs Forte's. Regarding the custom tune on Gen 3 Coyote builds is that just a function of the difference between stock settings and a tune more specific to a lighter/smaller car? I'll need to dig into other posts to read more about them so thanks for the tip-off. Regardless I'll stick with the EFI as I don't want to deal with carbs/tuning in the mountains with 3k-4k elevation changes!
Junbug
Confused a little by your response. You have "Coyote Power Steering Complete Kit" listed as part of your order from Factory Five. That is the KRC setup. You questioned whether needed w/ Mike Forte's Gen 3 Coyote. My response was to confirm you needed nothing from Forte for power steering since you picked the option from Factory Five. The Coyote crate motor comes without power steering. So Forte would leave it stock and you would install the setup from Factory Five (KRC) along with the power steering rack they provide as part of the option, and you're done.
Your response about the Coyote and tuning is a little confusing too. The Coyote is an EFI engine out of the box. Actually has two systems. Fuel rail injection and direct injection. There's no option to run it without EFI. Well unless you get into crazy mods, replace the intake, etc. I'm sure that's not in your plan. Forte will deliver with the stock EFI setup. I assume you're using the Ford Performance control pack with the Coyote. By far the most common setup. It comes with a PCM calibrated by Ford Performance for a standard Mustang air box. There isn't room in these builds for that. Only a relatively small and simple 90 degree adapter, MAF tube, and air filter. As a result, the MAF calibration is way off and has to be adjusted in a custom tune. Additionally, for whatever reason, Ford's standard calibration also runs excessively rich. The engine will throw error codes (and run very poorly) until both of these are adjusted by a custom tune. Plus whatever else the tuner chooses to optimize. The lighter/smaller car isn't really a factor. At least not for the major issues I've described.
By all means do as much research on these topics as you like. I will only add this is solid information based on actual experience with multiple builds including two with Coyotes. My current Gen 3 Coyote powered Coupe is awesome. After it was tuned and sorted out. (Build thread in my sig line below.) My experience has been repeated by multiple builders.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Thanks for clarifying edwardb! I misread your original message and now completely understand what you were saying. Thank you for clarifying and I really appreciate the details on why the Coyote will need a tune, very helpful. I actually just attended the FFR Roadster build class last weekend, which was very worthwhile.
