Thanks Thanks:  24
Likes Likes:  114
Page 14 of 14 FirstFirst ... 4121314
Results 521 to 558 of 558
Thread: Yama-Bro's MK4 Build Thread - #9158 (Index in Post #1)
  1. #521
    Kearney Nebraska
    Inching ever closer to cramming this between the frame rails. With the help of my friend Lance, we mated the tranny to the engine this afternoon. And what a beautiful day it was to be in the garage!
    -Liberty's Gears modded TKO-600
    -McLeod clutch
    -Quicktime steel bellhousing
    -Speedmaster flywheel
    Serial #9158
  2. Likes BadAsp427 liked this post
  3. #522
    Kearney Nebraska
    Big weekend on the car. The engine is finally resting happily in the chassis and I'm really satisfied with how it went in and turned out. It will most likely need to come back out to do final assembly of the surrounding components, but this install should let me figure out the next steps, get us to the first start, and then onto the exciting go kart phase. Big thanks to my Dad, friend's Jon G & Lance L, and my son Cody for helping shoe horn this thing in there. It went in so nicely, that we managed to knock off a few other tasks as well.
    To get it in, we put the front wheels on car ramps and put the back end on some tall jack stands. We needed the front wheels raised to get the cherry picker's out riggers under the chassis and the back was raised just to help increase the angle to get the transmission in. It went well.
    It was nice having 5 sets of eyes on every corner as it went in. We managed to avoid scratching anything.
    The engine nestled in the frame. After getting the engine in we also installed the headers & installed and adjusted the clutch cable.
    Serial #9158
  4. Likes Papa, 460.465USMC, MSumners, Chainsaw liked this post
  5. #523
    Kearney Nebraska
    Here's a shot of the A frame that supports the back of the tranny.
    We put the stubby driveshaft in it's place. It fit perfect. FFR nailed this one.
    We installed this add on to the kit...a Metco driveshaft safety loop. Well worth the money in my opinion. If one of the universal joints ever goes out I'm going to want some thick steel between my hip and the driveshaft. I don't think the thin aluminum cockpit skin will stop much. The safety loop bolts onto the tranny a frame. No extra drilling required, although we did need to use a large Cresent wrench to gently persuade it not to interfere with the e brake cables.
    Shift lever installed. Vintage style with faux reverse lock out. Another add on to the kit. Need to find a shift knob that fits, unfortunately the one that came with the kit didn't fit. Not a big deal. I'm trying to decide between the vintage look or something custom...
    At one point we even threw the body on to check the alignment of the headers to the the openings in the body. The headers seem awfully high...like a whole inch over the marked opening on the body. Something I'll need to look into. Either way, its nice to see it with the body on. Here you can see the ramps in the front and the large jack stands in the back that we used to position it just right for the engine install.
    Getting ever closer to go kart day!
    Wyatt helping with a few finishing touches the next day.
    Serial #9158
  6. Likes Papa, 460.465USMC liked this post
  7. #524
    Nov 2021
    Texas!
    I may have missed it if you posted...
    What was the final size of your particular engine?
    I know it's based on the new BPE 302 block, but didn't know if you went 289, 302, 306, ...
    Rob Windsor
  8. #525
    Kearney Nebraska
    Quote Originally Posted by Windsor View Post
    I went with the 347, the 289 sticker on the air cleaner is a lie.
    Serial #9158
  9. Likes Windsor liked this post
  10. #526
    Nov 2021
    Texas!
    I noticed the 289 sticker and figured it was a means of sandbagging.
    Who de-strokes a 302?
    Rob Windsor
  11. #527
    Sep 2011
    Minneapolis, MN
    Nice job, Frank. Satisfying to see that engine sitting in its final home, isn't it?
  12. #528
    Kearney Nebraska
    Haha, I know, right!? I'm trying to get a vaguely vintage look thru out the whole car. I've seen several pictures of originals that had similar air filters with the same sticker. I figured the originals had 289s and there isn't much difference between a 302 block and a 289 block, so I thought I could get away with it. If nothing else it's a conversation starter...although, I'm not sure you really need that with these cars no matter what stage of completion they are in.
    Serial #9158
  13. #529
    Kearney Nebraska
    Yes it is! It feels great. One giant step forward!
    Serial #9158
  14. #530
    Looking Good Billy Ray, https://youtu.be/sCkiHxcBgXg I Mean Yama-Bro!
  15. Thanks Yama-Bro thanked for this post
  16. #531
    Kearney Nebraska
    I installed a mechanical throttle linkage on my car this weekend. FFR supplies a cable linkage with the kit. I've read of a lot of complaints about the cable setup, so I opted for Mike Forte's mechanical linkage. Its much easier to install with the body off, so it was a good time to do it. It also has more of the vintage Cobra vibe, which I'm all about. There's a ton of adjustment to it, so it took some fiddling to get it just right. Now that I have it, it seems absolutely perfect. It's super smooth with just the right amount of travel and resistance. I'm pretty happy with this linkage.
    Here's an overhead shot of the whole linkage from the gas pedal (middle right) to the Sniper EFI (lower left). The top of the foot box is removed in this picture.
    This shot shows the linkage connection to the EFI from the drivers side. Not shown in this picture, I ended up connecting some extra throttle return springs, that came in Forte's kit, from the throttle back to a bracket attached to the middle post in the intake.
    This view from the passenger side shows the footbox aluminum in place, but I took that out to make assembly easier. I put a hole in the side of the footbox where the pivot bar penetrates the panel. I placed a rubber grommet in the hole to give it a nice finished look.
    Here's another overhead view showing the linkage up by the firewall. There's a large 2" frame member behind the aluminum firewall that I attached the ball ends to. It made for a super solid mounting point, which will have zero flex when stomping the throttle. The slots in the arms allow you to adjust the ratio of gas pedal movement to throttle movement. I started off at approx 1:1. Like I said, it feels perfect right now, but I may adjust it once I start driving it.
    Here's a view looking up from inside the footbox. You can see the gas pedal and the linkage going up from there to the pivot shaft.
    Serial #9158
  17. Likes nucjd19 liked this post
  18. #532
    Dublin, OH
    nice pics of the throttle linkage. I also did a rubber grommet but put a brass bushing in the grommet to prevent that grommet from getting cut up over time.
  19. #533
    Kearney Nebraska
    Good idea!
    Serial #9158
  20. #534
    Member red.barchetta's Avatar
    Aug 2021
    Alberta
    The engine looks awesome and so does the rest of the build!
    I’ve been following closely as my build is very close to yours as I am waiting on the new blueprint blocks for my 427, and I also bought a Levy Racing brake kit.
    Thanks for the detailed build thread it’s helped a lot!
  21. #535
    Kearney Nebraska
    Quote Originally Posted by red.barchetta View Post
    Thank you sir! I'm glad the build thread is helping others! You are going to love your BPE 427!
    Serial #9158
  22. #536
    Kearney Nebraska
    I did some work on the cooling system. Installed the radiator hoses. As many of you know, the kit comes with a stainless steel corrugated hose that you cut to length and also comes with "adaptors" to do the end connections to the engine and radiator. It's meant to be a universal fit to work with whatever engine a builder might go with. I'm not super crazy about this setup and I've heard of leak issues. So I looked into other options. I didn't want to spend the money on the formed metal tubes, so I went with preformed rubber hoses for existing vehicles that have just the right bends. With just a quick search of the forum, I found some of Jeff Kliener's suggestions, that I started with...read on for more details...
    Here are the parts for the upper hose. One hose is for an old fox body mustang and the other is just a Napa generic 90 degree hose. I got the inline filler from Amazon. I liked the fabricated look it has going on. It does have a smaller sized radiator cap than what I was expecting, but it should work fine. If not, it's an easy thing to swap out later.
    1990 Fox body Mustang hose: Napa 8028 or NBH7865
    90 Degree hose: Napa 777
    Upper hose installed (pre radiator clamps). It came out very nice. Note: I had to cut both hoses to get the fit I was after. I only took a little bit off each end of the 90 degree hose, but with the larger hose I ended up removing some past the first two bends on one end.
    Lower hose parts. One hose is from an old Ford Thunderbird, the other is a common hose used on several Chevys of the 70s and 80s. I got the aluminum in line connector from Amazon. Nice piece.
    Early 1990's V6 Thunderbird hose: Napa 7364 or NBH7364
    For the front lower hose, I bent a wire in the shape of the hose I was after and took it to Napa and Oreilly's. They let me look thru the hoses until I found one that matched the bends I was needing.
    Orielly's part number: 20827
    It was hard to get a good picture of the bottom hose assembly, but I think this one shows it pretty good. The Thunderbird hose didn't require any trimming, but I had to cut about 6 to 8 inches off the Chevy hose. Once I got the length dialed in this came out perfect. I don't think there could be a better hose setup for these unless it was custom made. It manages to snake around the frame members, steering components, sway bar and suspension. All with out touching any of them. I plan to clamp the hose to the 'X' member of the chassis to keep the vibrations to a minimum.
    Serial #9158
  23. Thanks buttsjim thanked for this post
    Likes Fman, 460.465USMC, zarnold liked this post
  24. #537
    Kearney Nebraska
    Next up was the radiator overflow tank. The kit comes with a long stainless steel canister. Its nice, but a little too much bling for my tastes. Way to modern and custom looking for what I'm going for. I went with this universal Dorman tank. Its basic and doesn't draw attention to itself. Plus, as a bonus, you can see thru it to see how much fluid you have in your system!
    The Dorman tank...
    I installed it on the upper half of the passenger side F panel. I originally installed it on the lower part of the same F panel, but I had a couple friends tell me it wouldn't let the fluid flow back into the radiator that low. After looking for other places to mount the tank, I realized I could install the elliptical shaped patch panel in the F panel, which created a nice place to place the tank. As long as it doesn't hit the hood hinge mechanism, I should be good.
    Serial #9158
  25. Likes Mark Eaton liked this post
  26. #538
    South Australia
    Maybe your friends have never had a drink through a straw. You can mount the overflow tank anywhere below the radiator high point. As long as your hose connections are sealed, vacuum will do the work.
    Gen1 Coyote / TKO600 / IRS
  27. Likes Mark Eaton liked this post
  28. #539
    Kearney Nebraska
    Yes, I was thinking that when I mounted it low. They are telling me that vacuum has a limitation on how far down you can go. I left the holes there, so I can move the tank back. Maybe I'll try it once I get it on the road.
    Serial #9158
  29. #540
    Senior Member Jonathan D's Avatar
    Jun 2012
    New Brunswick, Canada
    Great build thread! I can't get over how many great tips I keep seeing after reading so many of these already...keep it coming! I'm also sending you a PM
  30. #541
    Kearney Nebraska
    More weekend progress...I assembled the flexible fuel lines that connect to the Holley Sniper EFI and figured out the engine bay mounting for the hard lines. Check out post 329 on how I pressed the ends in without the expensive tool. I did the same this time, but didn't use the heat.
    In the assembly I used:
    4X Fragola straight fittings, p/n: 20010-BL
    2X Russel adaptors, p/n: 640610
    Fragola Push Lock hose 815006 (24" for one and 18" for the other)
    Looking up from the front passenger side tire at the hard lines that are secured to the passenger side foot box. Those gold clecos will be rivets in the final assembly. I'd do it now, but I can't get the rivet gun in there with the engine in the way.
    Kind of a wiring mess now, but you can see the connections of the flexible hoses.
    Serial #9158
  31. #542
    Kearney Nebraska
    I had an issue where the clutch cable interfered with the oil filter and the motor mount causing the cable to make a couple slight bends, thus making the clutch pedal harder to push in than normal. FFR supplies an oil filter relocation kit, but I didn't have a good place to mount the filter and the reports on the forum is that it has a tendency to leak. A gent in this forum recommended a nifty Ford Performance 90 degree oil filter adaptor (Ford Performance P/N: M-6880-B50). See the thread here...https://thefactoryfiveforum.com/show...ation-location It was a simple install, however I spent way more time researching the perfect filter to use with it, only to find that the instructions for the 90 degree adaptor listed three options and one just happened to be the perfect filter. Read the instructions first, kids! Either way, I'm happy with the results. I had a Baldwin B2 filter but switched to the smaller Motorcraft FL-500-S.
    Here's a shot from the side showing the installation. The large black "bolt" threads onto the filter adaptor that is in the block. The blue machined piece is the adaptor. It pivots around the bolt, so you can mount the filter just about any direction you want. I tilted it forward about 45 degrees. This makes for great access when changing oil. You can see the black clutch cable in this picture. It no longer runs into the filter. It now has a nice uninterrupted run from the clutch quadrant down the the clutch fork...and its easier to push in!
    Serial #9158
  32. #543
    Kearney Nebraska
    My friend Lance and I tackled the power steering lines on the roadster last night. I wasn't content with the lines that were supplied from Factory Five Racing, so I purchased a really nice kit from Breeze Automotive, p/n: 70781. The kit includes everything you need to painlessly connect the supply and return lines from the pump to the steering rack. The kit came with excellent instructions. I forgot to get a pic of all the parts before the install, but there's a pic on Mark's website. Once installed, they look great! A short direct run and very clean looking. I'm pretty happy with them.
    We also filled the tranny with fluid. My suggestion is to fill the tranny before putting it in the car, as it is very tight quarters in the tranny tunnel.
    Serial #9158
  33. Thanks cc2Arider thanked for this post
  34. #544
    Sep 2022
    And....in order to follow-thru with your suggestion, some sort of plug or driveshaft input needs to be installed so the fluid doesn't leak out during the install?
    Craig C
  35. #545
    Kearney Nebraska
    Quote Originally Posted by cc2Arider View Post
    Craig C
    Yes, you are correct. Good point. We pulled my son's truck's tranny twice recently. To plug the output shaft hole we dug thru the recycle bin and found a plastic hairspray bottle that was just about the same size as the driveshaft stub. I cut off the bottom of the bottle so only a .25" or so protruded from the tranny once it was inserted. It worked perfect.
    Serial #9158
  36. #546
    Kearney Nebraska
    Hey Guys!
    It's been awhile...We made it to the first start!!! Click on the pic to see the video.
    Serial #9158
  37. Likes M. Townsend liked this post
  38. #547
    Congratulation From The Dark Dart Side Mr. Bro!
  39. #548
    Southern Ontario/Cape Coral FL
    Awesome! I was checking milk cartons for you!!
    Higgy
    MK4 #11173 picked up 01/20/25
    MK4 #11012 picked up 04/16/24
    MK4 #10616 picked up 4/10/23 SOLD
    MK4 #9759 picked up 4/3/19 SOLD
  40. Likes GoDadGo liked this post
  41. #549
    Sep 2022
    Good to hear from you again! Congratulations on that milestone
    Craig C
  42. #550
    Kearney Nebraska
    Quote Originally Posted by Higgybulin View Post
    Higgy
    Craig C
    Thanks Guys! Glad you still remember me. Haha, I'm hoping that the go cart milestone won't be such a long wait.
    Serial #9158
  43. #551
    Kearney Nebraska
    Hey my FFR Friends!
    As I approach the 7th anniversary of the day a frame, a body, and a intimidating pile of boxes were dropped of in my garage, I reach another milestone. This milestone is an exciting one for it is the 1st "go-cart" of my FFR Roadster. Thanks to Nathan B for manning the camera and being ready to call 911 should the need arise. I am happy to report everything worked excellent and we managed to rack up the first 2.2 miles on the odometer.
    Click on the pic to see the video...
    Serial #9158
  44. Likes Higgybulin, 460.465USMC liked this post
  45. #552
    Senior Member danmas's Avatar
    Jan 2019
    Mead Colorado
    Hey my FFR Friends!
    Very cool!
    Current BOM
  46. Likes Yama-Bro liked this post
  47. #553
    Hey my FFR Friends!
    Frank! Good job man, go slow turn left is always a good option for the 1st go kart! That Blueprint was sounding good, kodos to the guy that helped design that! And we gotta talk about the hair brother!!! Great flow bro!! Lol
    Now get back to work on that thing! By the way, need some details on that square body!!
    Higgy
  48. #554
    Sep 2022
    Nice! I love that grin of SATISFACTION!
    Craig C
  49. Likes Yama-Bro liked this post
  50. #555
    Congrats and good on ya!
  51. Likes Yama-Bro liked this post
  52. #556
    Kearney Nebraska
    Thanks for the comments guys!
    Higgy
    Ah yes, the square body...you may have discovered just one of the side projects that borrowed some time from the FFR. LOL. But it's a good thing. This is my oldest son's '83 GMC truck. He bought it with lawn mowing money when he was 15 (he's almost 20 now) and has continued to pour his cash and heart into it since. It started with an inline 6, 3 speed tranny, 15 inch rims and a questionable paint job. Once he got the hang of driving, we swapped in a BPE 383 stroker and then later a 5 speed tremec. Cody did the complete interior which consists of bucket seats, a custom made console with touch screen entertainment system, and starlight headliner. He picked up the wheels and tires last summer. The truck was lowered a bit when he got it, but it's gone lower since via belltech lowering kit and including a C notched frame. We put 3.93 gears and a Eaton locker in the rear end. This whole project has made Cody realize that his passion is building custom cars, especially the painting part, so after he graduated last year, he enrolled in autobody. He's also been working part time for a guy that does some custom cars. Cody did the body work and painted the truck towards the end of his first year of college and during this summer. The picture here is from a car show this summer...two days after he finished the paint. He has more plans for it in the future (super charged LS ), but it's definitely transitioned from the lawn mower hauling rig to more of a garage queen. It's no doubt the project has shaped his future career.
    Serial #9158
  53. Likes Higgybulin, Papa, Nigel Allen, 460.465USMC liked this post
  54. #557
    It's great to see it on the road! The grin on your face says it all.
  55. Likes Yama-Bro liked this post
  56. #558
    BadAsp427's Avatar
    Greeneville, TN
    Awesome milestone... your grin say it all.... I remember that day well. Congrats
  57. Likes Yama-Bro liked this post
