pressing IN IRS wheel studs
I plan on using the "Vice & Deep Socket" method to press OUT the studs that come in the hubs. Any reason not to reverse the process and press IN the new studs? Seems easier than running a lug nut and washer down like the manual describes and closer to an actual wheel stud press. Just checking to see if I'm overlooking something obvious here.
25th Anniversary #9772
mmklaxer
yep, press them in no issue - had a buddy with a nice press snug them up to 5,000PSI
A lot of people do it that way. Just make sure you have a quality heavy duty vice. HF won't do it.
Put the studs in the deep freeze for a day or two. They will shrink a bit. Easier to get them in, and they will be tighter when they warm up.
