Results 1 to 3 of 3
Thread: pressing IN IRS wheel studs
    Senior Member mmklaxer's Avatar
    Kennebunk, ME
    I plan on using the "Vice & Deep Socket" method to press OUT the studs that come in the hubs. Any reason not to reverse the process and press IN the new studs? Seems easier than running a lug nut and washer down like the manual describes and closer to an actual wheel stud press. Just checking to see if I'm overlooking something obvious here.
    Folsom, CA
    Quote Originally Posted by mmklaxer View Post
    yep, press them in no issue - had a buddy with a nice press snug them up to 5,000PSI
    Todd
    Colorado Springs
    A lot of people do it that way. Just make sure you have a quality heavy duty vice. HF won't do it.
    Put the studs in the deep freeze for a day or two. They will shrink a bit. Easier to get them in, and they will be tighter when they warm up.
    .boB "Iron Man"
    www.RacingTheExocet.com
  4. Thanks mmklaxer thanked for this post
    Likes Chopper liked this post
